Which gasket for O-ringing head?
Old Jan 26, 2010 | 01:48 PM
93_Fummins's Avatar
Default Which gasket for O-ringing head?
I'm getting ready to tear down my 2nd gen 12v and get the head O-ringed. Thinking I was thinking ahead, I ordered the studs and a replacement STOCK head gasket. I was under the impression that O-ringing used stock gaskets and fire-ringing used modified gaskets. Weeeeeeeell, then I open up my new Diesel Power mag this afternoon and see that they O-ringed the Rust Busket and used a .020 over gasket.
So, question is, do I need the oversized gasket, or can a stocker be used?
Being that I only have a few days I can get off to get this done, I'd like to have all the parts ready before the head gets back...
Old Jan 26, 2010 | 04:13 PM
94 12valve's Avatar
I'm pretty sure you can use a stock gasket ... and which diesel power did they o ring rust bucket? hope I didnt miss one.
Old Jan 26, 2010 | 04:26 PM
93_Fummins's Avatar
Yeah...looks like I might not O-ring the head anyway. Turns out none of the nearby shops do O-ringing, just fire-ringing.
As for Rust Bucket, March 2010 Issue...just got it in the mail today.
Old Jan 26, 2010 | 05:05 PM
daveO's Avatar
Yeah, you can use the stock head gasket. The .020" larger one is referring to the thickness, which will lower compression a little bit.
Old Jan 26, 2010 | 05:32 PM
12valvetater's Avatar
I have a stock gasket in mine.
Old Jan 26, 2010 | 06:18 PM
oglejust's Avatar
you only use the .20 gasket if u have the head milled
Old Jan 26, 2010 | 11:43 PM
You can use the thicker gasket if you want to drop the compression a touch.
Old Jan 27, 2010 | 09:52 AM
Hammer's Avatar
Alot depends on how much they took off of the head when they milled it.
Many will run a .010 or a .020 marine gasket instead of a stock gasket.Again it depends on how much of the head was milled to make it flat.
On mine I run a .020 marine gasket becuase of what was taken off of my head and I want the compression lowered a tad for higher boost levels.
Old Jan 27, 2010 | 10:08 AM
93_Fummins's Avatar
Okay, so I'm still sitting pretty if I do happen to find a place to do the O-rings.
Thanks guys!
Old Jan 27, 2010 | 12:19 PM
oglejust's Avatar
ive talked to a few guys that put a thicker gasket on to lower compression and they smoke at an idle bc of it
