'03 6.0L. cold start runs rough
Old Jan 26, 2010 | 09:35 AM
rtaggs's Avatar
Default '03 6.0L. cold start runs rough
hi. my 03 f550 with the 6.0 runs rough on cold start. it sounds like it is running on three cylinders for a few minutes. it will even do this in the summer. i have just recently gotten a code p02285, for icp sensor circuit low. it has never had codes but always ran rough. any suggestions would be appreciated.,
thanks.
Ron
Old Jan 26, 2010 | 05:26 PM
Mdub707's Avatar
How many miles on the truck? How long since your last oil change and fuel filter change?
When's the last time the truck was re-flashed? Do your injectors buzz before start up or after shut down.
You may just need a newer flash (inductive heating flash), or you could have injectors/FICM going out... hard to tell.
Old Jan 27, 2010 | 05:09 PM
KLOVE's Avatar
You may just need a newer flash (inductive heating flash), or you could have injectors/FICM going out... hard to tell.[/QUOTE]
had all this done and put and icp sensor on it and it fix it
Old Feb 4, 2010 | 07:38 AM
rtaggs's Avatar
60,000 miles..fresh oil and filters... no buzzing before start up or after shutdown.
Old Feb 4, 2010 | 08:07 AM
DieselDanBoy's Avatar
so the problems fixed?
Old Feb 4, 2010 | 01:22 PM
rtaggs's Avatar
not yet.. i was going to change the icp sensor until i saw where it was. now it will have to go to the dealer.
Old Feb 4, 2010 | 05:34 PM
if im not mistaken, if the icp sensor fails i think the ecu gives out a set pressure so it will stay running, sort of a limp home mode. it should still start and run though.
Old Feb 12, 2010 | 12:59 PM
Begle1's Avatar
What's an "ICP"? I'm crosstraining in Ford for a job interview on Monday.
Old Feb 12, 2010 | 02:00 PM
BUBBAJON's Avatar
Yeah, i would like to know what ICP is to. And curious of how often the trucks need to be re-flash.
Old Feb 17, 2010 | 10:30 AM
rtaggs's Avatar
Injector Control Pressure sensor, located behind and below the turbo
