Headlights Dropping or Cutting Out!
Old Jan 26, 2010 | 05:57 AM
millco's Avatar
Default Headlights Dropping or Cutting Out!
Recently the headlights have started cutting out or blinking off and right back on in my '06. It is very fast at it, but still if you don't blink your eye lid you can see it. I couldn't find any posts about anyone else's truck doing it. There is no code for it and nothing has been done to any wiring on the head lights. They both do it at the same time. Since the head lights are wired separately between left and right, I would think it would be in the TIPM. Any one got any ideas?
Old Jan 26, 2010 | 06:53 AM
dangerous1965's Avatar
That's a good one! Still under warranty? Check your grounds and fuse panel. Do the wire wiggle test and check the connections!
Old Jan 26, 2010 | 06:55 AM
Whit's Avatar
Site Mascot
does it do it all the time or just cold or what
Old Jan 26, 2010 | 03:42 PM
lunk's Avatar
your grid heater comes on and off when temps are 40 or below while driving or idling. it takes a lot of juice and makes your lights dim slightly then brightin back up
Old Jan 27, 2010 | 07:12 AM
millco's Avatar
There doesn't seem to be a pattern to it. I have seen it do it as often as every minute or two and other times only once during a trip. Doesn't seem to be associated with bumps or anything like temps or what ever.
I haven't had my grid heater hooked up in about two years so I'm sure the dimming I was used to seeing is not this. No, this is an instantaneous off and right back on. It is only off for a fraction of a second, but it doesn't dim or anything. Just instant off and right back on.
Of course it is just out of warranty.... Figures!!
I did have one thought hit me: I put in PIAA bulbs about the time this started (Give or take. One of those things I didn't realize or pay attention to!). I would have swore the package stated they were very similar in wattage to OEM specs. I think I will look into this a little more. Course I could just make my own poor man's Bright Bulb mod with some relays. Maybe if I put a capacitor on the switch wire it could 'carry over' long enough to keep my lights on during these very short outages..... (Unless they decide to get longer! )
Old Jan 29, 2010 | 08:44 AM
sinwagon's Avatar
mine does it too it is deffinatly not the dimming from the grid heater. mine doesnot do it all the time just kind of notice it from time to time. my lights are stock and no fog lights.
Old Jan 30, 2010 | 06:59 AM
millco's Avatar
Hmm.... Well, so much for my theory of the bulbs being too high of wattage. I haven't had time to find / check the package yet, but if memory serves they were really close to OEM levels.
Seems kind of odd doesn't it. I still think it is the TIPM. I will have to keep an eye out for another in the salvage yard and see if I can grab one to try / have for a spare.
drgracen
Aug 11, 2015 12:21 PM
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
smokee
Feb 14, 2015 12:09 PM
MIKE3822
Nov 4, 2014 07:34 AM
