thermostat
Old Jan 25, 2010 | 11:07 PM
dan33klein's Avatar
Default thermostat
ok, my truck does the whole thing on how the needle jumps between 190-140. i heard that can be fixed by the new thermostats from cummins. is it realy nessasary to change it? will it hurt anything the way it is now? whats the p/n for the new one?
Old Jan 25, 2010 | 11:10 PM
94 12valve's Avatar
my 94 has done that since I first bought it, I dout it will hurt anything
Old Jan 25, 2010 | 11:15 PM
dan33klein's Avatar
thats what i was thinking. it always just catches my eye and worries me
Old Jan 25, 2010 | 11:20 PM
94cummins12v's Avatar
dan dont worry about it its not like a gas engine were they constanl stay open they open around 180 which is when you see it drop i was worried about it also when i rebuilt my motor went threw 3 thermostats from cummins and they all did it
Old Jan 25, 2010 | 11:55 PM
nate379's Avatar
Dunno why, but some trucks do it and others don't. Mine doesn't normally, but we had around 15 Dodges where I worked a few years ago and they all did it. 96 and 98 12v mainly but a couple 24v as well.
Old Jan 26, 2010 | 06:40 AM
PhilipR's Avatar
Mine used to float around then my rad sprung a leak. So I chaged it out along with all the hoses and put a new Cummins T-stat in. I also used Global Charge coolant and flushed the system. Now my gauge climbs up to 180* and rides it....it moves a little in the summer when towing but usually stays right around 180* all the time. That actually bothered me for a long time cause I was used to the temp gauge swinging.
Old Jan 27, 2010 | 04:30 PM
IH1206's Avatar
i was just wondering the same thing, my truck will be all warmed up at 180 , next thing i know it is below 140 wierd aint it
Old Jan 27, 2010 | 08:19 PM
R&RDiesel's Avatar
FormerVendor
Perfectly normal, even the new cummins t-stats do it, will not hirt anything.
Old Jan 29, 2010 | 08:35 AM
smoken's Avatar
I recently installed the updated thermostat from Cummins, and I am still getting a 10* temp swing.. I really see no harm as long as it doesn't go over 200*
Dustin M
May 21, 2015 10:19 PM
Brody Olson
Mar 28, 2015 05:14 PM
klein444
Mar 8, 2015 08:19 AM
mmnot
Mar 2, 2015 07:12 PM
