A518 and 47rh
Old Jan 25, 2010 | 03:49 PM
pewder's Avatar
Default A518 and 47rh
Aren't these the same transmission? Or am I getting something totally wrong here ha ha
Old Jan 25, 2010 | 03:52 PM
12vcummins96's Avatar
yeah they are pretty much the same unit
Old Jan 25, 2010 | 04:03 PM
Begle1's Avatar
No.
In Dodge-Cummins parlance at least, A-518's were the 91.5-93 non-lock-up 3+1 speeds, the 47RH's are the 94-95 lock-up 3+1 speeds.
I do believe that the A-518's in the gasser trucks had lock-up, but not the Diesel-spec transmissions.
A-518's are also referred to as "46rh"'s.
Old Jan 25, 2010 | 04:31 PM
muskrat's Avatar
Originally Posted by Begle1
No.
Begle nailed it.
Old Jan 25, 2010 | 07:16 PM
tltruckparts's Avatar
yep hes totally correct. the 518 and 47rh are off of different generation trucks
Old Jan 25, 2010 | 11:55 PM
pewder's Avatar
Thank you very much! So when looking for a torque converter I need to make sure it is for the A-518 or a 46rh? Hard to find a lot of info on these dang transmissions. Can anyone get an illustration that shows what plug is what on these transmissions. I have wiring to two of these plugs that are fried, need to find out what they go to. Also need to try to find a section of wiring to replace it.
What do you guys suggest for the stall on the torque converter?
Old Jan 26, 2010 | 12:05 AM
muskrat's Avatar
Here is the manual from the sticky.https://www.dieselbombers.com/1st-ge...on-manual.html
Hope it helps.
Old Jan 26, 2010 | 12:27 AM
pewder's Avatar
It doesn't show what sensor is what. I the one at the very rear is the speed sensor and it's not the temp sensor that comes off the tube, it's the other two.
Old Jan 26, 2010 | 07:02 AM
yeah they are from different generations but they are the same damn unit the only difference is a locking converter all the inners are the same except the input shaft
gees people i built these units for years now i should know
Old Jan 26, 2010 | 07:22 AM
BC847's Avatar
