Squeaking from drivetrain? Haynes or Repair Manual?
Old Jan 25, 2010 | 11:28 AM
Big_Krash's Avatar
Default Squeaking from drivetrain? Haynes or Repair Manual?
I have an 03 Chevy ext cab long bed 2wd and one i first start moving i get a squeaking from the driveline. I had the Guys at Eastern Offroad check into it when the replaced the stock shock with some Bilesteins and they said it was comming from the driveline... Any thoughts? Also is there an aftermarket repair manual for the Duramax? i didnt get the specific diesel book when i bought my truck from the dealer? Thanks
Old Jan 25, 2010 | 12:41 PM
Rttoys's Avatar
I think that's a 2 piece driveshaft, check the carrier bearing on the driveshaft. Push up and down on the driveshaft and see if the rubber is come on the carrier bearing.
Next place to look will be the front wheel bearings.
Old Jan 25, 2010 | 12:45 PM
Big_Krash's Avatar
Default Noise from drivetrain
it is a two piece Driveshaft, it has some kind of rubber flex over right before the mid mount crossmember... the driveshaft doesnt move at all... and its comming from the rear of the truck any other thoughts?
Old Jan 25, 2010 | 01:32 PM
Rttoys's Avatar
Could be as simple as a dry u-joint. You can pull the 4 bolts that hold the driveshaft to the rearend, pop the driveshaft out and move the u-joints around and feel for any rough spots. Pull the 2 caps off and see if they are dry or is the needle bearings are messed up.
*Just to be sure we are talking about the same thing from my previous post, the center piece that attaches to the frame crossmember is the carrier bearing. That rubber around the driveshaft is very common to come apart and start making noises. Just make sure it's not worn OR looks brand new. Someone may have just replace it (or even the u-joints) and may not have done it right.*
Can you bounce up and down on the rear of the truck and make it squeek?
Old Jan 25, 2010 | 02:57 PM
Big_Krash's Avatar
Default drivetrain squeak
If they are dry is there a zirk fitting for a grease gun? No squeak when i bounce the truck only when rolling at low speed under 10 mph after that i dont hear it.
Old Jan 25, 2010 | 03:05 PM
Rttoys's Avatar
If they are stock origional u-joints, then no, there is no zerk. If they've been replaced, then maybe, depends on the brand that was installed.
Old Jan 31, 2010 | 08:14 PM
Big_Krash's Avatar
Default vibration while driving now
As if the squeek in the drivetrain wasnt bad enough getting a vibration when driving... any thoughts before i go to the stealer???
Old Mar 24, 2010 | 07:06 PM
Big_Krash's Avatar
took the u-joints out, front and read after the carrier bearing....
squeaking is gone... thanks for the help
Karl
MIBoondocker
Jun 20, 2015 11:56 PM
