370's???
Old Jan 24, 2010 | 04:27 PM
rollincoal12valve's Avatar
Default 370's???
what should i do to my truck tuning wise if im adding a set of these??? im gettin a deal on a set tommorow, i know i need a turbo but for now what can i do to keep this thing safe?
Old Jan 24, 2010 | 04:46 PM
smokedout's Avatar
haul *** and have fun 370s smoke like a freight train and put out pretty good to.I love um
Old Jan 24, 2010 | 05:55 PM
Cody Cummins's Avatar
Running more air to keep that motor cool, and keep your eye on that egt gauge. It's gonna roll coal and put them temps up there a bit!
Old Jan 24, 2010 | 06:11 PM
94 12valve's Avatar
use thin injector washers and bump your timing
Old Jan 24, 2010 | 10:02 PM
12valvetater's Avatar
X2 on the washers and timing. Slide your plate back a bit.
Old Jan 25, 2010 | 11:03 AM
PhilipR's Avatar
Mine are fairly clean with the thin washers and I am having my timing bumped to 16* and it should be even better. i was told there were different sets of 370's though and some are a bit cleaner....I don't know how true that is or if it's total BS.
Old Jan 25, 2010 | 12:06 PM
FastCR's Avatar
the better ones have a modified spray pattern for truck pistons instead of the marine pistons.
Old Jan 25, 2010 | 03:16 PM
how far back should i slide it? and will i lose power by doing this or will the injectors make up for the fuel
Old Jan 25, 2010 | 03:17 PM
PhilipR's Avatar
My plate is FF and I can hit 1200* pretty quick but I don't run the sack off my truck and I keep and eye on the pyro when I do get on it.
Old Jan 25, 2010 | 03:24 PM
12vcummins96's Avatar
they are hot injetors unless you get the aftermarkets like new era
