Another smoke question
Old Jan 24, 2010 | 02:23 PM
BroncoGod's Avatar
Default Another smoke question
Lately my truck has been smoking a fair bit when I first fire it up in the morning.Once it starts warming up it smokes less and less, but even once it's warm the truck still smokes alittle.I cant see any when I drive, but when I stop and get out theres a little bit. It's blue smoke.Any help would be great.
'07 powerstroke
Diablo trinity
4" turbo back straight pipe
Old Jan 24, 2010 | 02:46 PM
5.9Bronco...eventually's Avatar
my guess would be a small oil leak. The oil is prolly getting moved faster when you drive and doesnt leak any.
But that is just my guess. I would not know for sure
Old Jan 24, 2010 | 02:58 PM
cumminsdad08's Avatar
mine smokes a little blue when i first start it, warm or cold most of the time. but usually goes away shortly afterward. i never worried much about it.
Old Jan 24, 2010 | 05:05 PM
BroncoGod's Avatar
what about injectors, or do they normally smoke white when the get ratty. I also get a tick sometimes at full throttle, sounds like valve train noise but a little bit slower, not sure if its relevant to my problem or not
Old Jan 24, 2010 | 06:42 PM
from what I know about this, this is just from reading this forum. blue smoke is oil, white is raw unburnt fuel, black is partially burnt fuel, and gray is a combo of the unburnt and partially burnt fuel.
That is what I read somewhere on here when someone had a smoke color question. So I wouldnt think it is the injectors except you do have HPOPs on the 6.0s right. that might have something to do with it but I really am no expert. I just read like this site a lot.
Old Jan 24, 2010 | 06:51 PM
......you could look the other way when you get out of your truck, that might help.........
Old Jan 25, 2010 | 06:23 PM
BroncoGod's Avatar
now the truck is devoloping a miss and started running rough whether its cold or warm and smoking more. Hopefully I can get it figured out before it gets to expensive, it's my only truck. Also it's not throwing any codes.
Old Jan 25, 2010 | 06:57 PM
04redstroker's Avatar
sounds like injectors but its hard to say over the comp. How many miles are on your oil?
Old Jan 25, 2010 | 07:18 PM
BroncoGod's Avatar
I have about 300 miles since my last change
Old Jan 26, 2010 | 12:08 AM
Mdub707's Avatar
How many miles on the truck? Blue smoke is oil. Could be something as simple as a turbo seal.
My 06 has this issue right now. It's fine, until fully warmed up. When I'm cruising its normal, when I come up to a stop sign (let off throttle and slow down) then take off again, I get a puff of blue smoke out the exhaust.
