starting problems?
Old Jan 24, 2010 | 12:39 AM
sparkplugsr4pussys's Avatar
Default starting problems?
I have a 96 12 valve and im not sure whats going on but i have to hit the throttle when turning over to make it fire up, i have had people tell me that it is probably a cracked fuel return line but was not to sure. any advice?
Old Jan 24, 2010 | 12:49 AM
Well the first thing to do is to make sure that your idle is set correctly.
What rpm does it idle at when in gear?
Have a look at this: Ram Diesel Problems
It could also be getting some wear on the injector pump - how many miles?
Its not real uncommon for 12V guys to have to give it a little pedal to get it to start. I would suspect that you need to bump your cold idle just a touch.
Welcome BTW.
Old Jan 24, 2010 | 02:06 AM
lodal cummins's Avatar
that is normal! you have to give it a little juice to get it to fire!!!!!!
Old Jan 24, 2010 | 08:35 AM
12vcummins96's Avatar
i give it a little everymorn just helps it fire up quicker
Old Jan 25, 2010 | 01:59 AM
it idles at 800 in gear and 1000 when in park or neutral, it has 194000 on it
Old Jan 25, 2010 | 04:46 PM
Threesixty's Avatar
I never had to touch the gas pedal on mine, but I live in S.Texas.
If it was a cracked return line it would be dripping diesel when the engine's running. And you'd constantly smell that raw diesel whenever exiting the truck, like if near a gas station.
Old Jan 25, 2010 | 09:05 PM
Cummins Express's Avatar
sounds to me like a tweaked stock gov spring set that is set too tight, and the idle was jacked up to compensate for it. Classic symptom of a mis-adjusted governor spring.
Chris
Old Feb 1, 2010 | 07:33 PM
Rexy's Avatar
Mine did the same thing. I replaced both rubber fuel lines. The one behind the fuel filter had a small crack.
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
tom88k5
Jun 16, 2015 12:57 PM
angies04
Sep 29, 2014 04:11 PM
