gauges
Old Jan 23, 2010 | 02:14 PM
hulse09's Avatar
Default gauges
where is the best plase to tie into for lighting boost pyro ect gauges on a 2000 dodge ram 2500
Old Jan 23, 2010 | 02:38 PM
blkjack's Avatar
I just tapped in right behind the light switch. I took off the Inst cluster bezel and pulled the switch out and with a voltmeter found the wire that dimmed with the rheostat and tapped into that wire cant remember which color the wire was but that was the easiest to get to and know which wire was the right one.
Old Jan 23, 2010 | 07:14 PM
Turbohunter's Avatar
Thats the same thing i did as well. Not hard to do
Old Jan 23, 2010 | 09:58 PM
2500superram's Avatar
i tapped mine in the fuse box,just got to make sure it's the correct side of the fuse.i wire'd in a relay for it and that wire is the trigger.i'm not able to make mine dim,like using the headlight switch though.
Old Jan 24, 2010 | 12:10 AM
If it doesnt dim you are on on the wrong circuit. Try using the Illumination fuse (sorry, cant remember the number).
Heres mine: the first pic shows the Add a Circuit I used to power the pyrometer and trans temp guage, and the second shows the fuse tap that Im using to power the lighting for the guages:
Old Jan 24, 2010 | 08:25 AM
i'm on the 5a illumination fuse.it might be because it is used to trigger a relay that i wired for the light's.i daisy chained all the bulbs for the gauge's off the one relay.
three of my gauge's are in a dash pod,which put's them furthur away from me.i almost want to make them brighter
i used the add a circuit's also
flainn
Oct 12, 2024 09:39 AM
Powerstroke36
Sep 6, 2015 02:41 PM
May 1, 2015 08:10 AM
Justin82
Price Quote - Request A Price
Apr 1, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Dec 9, 2014 03:58 AM
