Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Need tip on building a pulling truck
Old Jan 23, 2010 | 08:49 AM
STUMPMAN's Avatar
Default Need tip on building a pulling truck
I've got an 89 Chevy 2500 that I'm going to build into a pullin truck. I'm replacing the the front axle w/ dana 60 and going to put a 12v Cummins in it. I'm going to use a 4500 for transmission. I'm curious what type of suspension set up works best for Pulling, Leaf sprung or coil over? also what gears, and tire sizes are people running? Hitch and ride heigh? how far can the weights extend from the front axle? Any tips, pictures, and advice are welcomed. Thanks in advance!
Old Jan 23, 2010 | 10:33 AM
R&RDiesel's Avatar
FormerVendor
Well your starting off good with the 12v and the dana60, and tranny, as far as suspension, you will probably have better luck with coil over in the front, the rear well, probably leafs, depending on the class or organazation you will be either fully blocking or limiting the travel in the rear. With a 5sp tranny you will probably need to run 4.88-5.13 gears. 33 or 35 12.50 tires. Hitch all depends in class,i assuming a street style class, you will be limitied to your reese style hitch, but i would move it twords the front of the truck on the frame. buy or make a good adjustable hitch, most places or 26" hitch hieghth. Weights can extend no more than 60" fron the centerline of thr front axle.
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
wannadrag
May 25, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Mikeyfz45083
Nov 14, 2014 11:04 AM
Oct 14, 2014 08:40 AM
