edge comp drag box
Old Jan 22, 2010 | 05:51 PM
jack34's Avatar
Default edge comp drag box
i have a edge comp drag box with stock set up what needs to be done? to support this
Old Jan 22, 2010 | 05:53 PM
Please post in the correct forum.
Welcome.
Old Jan 22, 2010 | 05:58 PM
jack34's Avatar
i dont know how
Old Jan 22, 2010 | 06:44 PM
Codgedodger's Avatar
FormerVendor
I dont fully understand what your asking...
Old Jan 23, 2010 | 05:22 AM
redneck_cummins's Avatar
Need to get gauges fuel pressure(TOP PRIORITY), boost, and egt), better fuel system airdog or fass, and then a better clutch. That should about do it. Good luck and welcome to the site
Old Jan 23, 2010 | 06:36 AM
Jazz's Avatar
Like said above
Fuel pressure gauge is definitely needed on stock or modded trucks. The lift pumps are known to go out on these trucks and when they do you can still drive them normally for a while without knowing sometimes and it will eventually take out your injection pump, which is quite expensive compared to a lift pump A exhaust temperature gauge would be a very good idea so you don't get to hot and melt it down. With a drag comp and stock injectors and turbo I think you will still see some pretty hot temps. Do you tow?
scottxmorris
Jan 11, 2025 11:24 PM
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
FF131
Jan 21, 2015 11:37 AM
scottxmorris
Dec 31, 2014 03:20 PM
