injector lines
Old Jan 22, 2010 | 05:18 PM
cumminskid92's Avatar
Default injector lines
i just put a head gasket on my truck but now i can not figure out which injector lines go where and what order i need to put them on.
Old Jan 22, 2010 | 07:02 PM
tltruckparts's Avatar
they are hard lines so its just kind of put them up there and see where they send you type of thing. IIRC the number one slot was at the very bottom of the cylinder. but its been a while since ive seperated them all. if you compeltely seperated them and took out the things that holds them together it can be a real pain.
i do remember though that the set of 1st 2nd and 3rd all skip inbetween i dont really know how to explain it. there are six holes for the injector lines obviously if you only hook up the first three cylinders, i remember that it would have a missing line on every other one, and same if you were to do only the 4th 5th and 6th.
im sorry if it doesnt make sense. if someone else cant chime in ill draw you picture and post it
Old Jan 22, 2010 | 11:24 PM
seandonato73's Avatar
they will only fit on one spot, shouldn't be too hard to figure out.
x2 on those stupid clips, the little nuts can be a real pain in the buttox
