Turbo Drain Line?
Old Jan 20, 2010 | 09:56 PM
98dodgecummins's Avatar
Default Turbo Drain Line?
Hello well last night i was changing my oil and when i too k oil filter off i seen there was a big metal line that comes out the bottom of my turbo and goes down back into the block is that a oil drain line for the turbo. When i seen it i seen that their was a 3 inch spot taken out of it where someone spliced it with a rubber is that bad?
Old Jan 21, 2010 | 07:35 AM
turbo20psi's Avatar
Yep thats the oil return line form the turbo,thats how they come from the factory.Hard line to a piece of rubber line connecting to the nipple coming out of the block.
Old Jan 21, 2010 | 07:40 AM
Whit's Avatar
Site Mascot
is this on a 12 valve or 24 valve you speak of?
the 98 is a 12 valve and the 98.5 is a 24 valve
Old Jan 21, 2010 | 08:31 AM
it is a 24 valve 98.5
are those lines bad about leaking where the end of the pipe is stating to go into the block because mines leaking a little?
Last edited by 98dodgecummins; Jan 21, 2010 at 08:31 AM. Reason: Automerged Doublepost
Old Jan 21, 2010 | 08:57 AM
Whit's Avatar
Site Mascot
get ya a new piece of rubber hose on there......yers may be dry and cracked
Old Jan 21, 2010 | 09:31 AM
OK
IT ALSO LOOKS LIKE IT IS LEAKING FROM THE tube that is going into the block?
Old Jan 21, 2010 | 09:34 AM
Whit's Avatar
Site Mascot
Originally Posted by 98dodgecummins
OK
when you remove that tube where it goes into the block you will find an O-ring there...........replace that too
avatardvr
18
Aug 8, 2019 12:38 AM
rodbuilder
Jun 26, 2015 12:48 AM
CumminsCoalRoller24/7
Apr 21, 2015 09:03 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
