Help me save my friend
Old Jan 20, 2010 | 07:18 PM
brando's Avatar
Default Help me save my friend
My buddy owns an 04 6 litre. He has been through three turbos already because that's what the dealer keeps telling him is wrong, he will lose power while dirving. About three months ago he was dirving and truck lost power(this is the third turbo he's on right now) had his foot to the floor and could only go like 20-30 mph. This exact same thing happened again about two weeks ago. The dealer keeps blaming him saying he needs to put fuel additive in his truck. The truck is out of warranty and there's no way he's going to throw money away on a new turbo when that has never fixed the problem. What do you guys think it could be? Thanks for all the help.
Old Jan 20, 2010 | 07:43 PM
Lil Red Express's Avatar
I had a friend with a 04 with the same problem and it ended up being injectors.
Old Jan 20, 2010 | 08:06 PM
brando's Avatar
How'd he test em? Buzz test or pressure test em?
Also I've seen that he should upgrade oil drain tube would that have anything to do with this?
Old Jan 21, 2010 | 08:14 AM
96blackcloud's Avatar
6.0 injectors run off oil pressure i think if there isnt enough oil pressure they wont fire right could be source for lack of power idk
Old Jan 21, 2010 | 09:01 AM
grabber1's Avatar
I had this same kind of prob with my 04. It ended up being a ICP Sensor. He may need to have the new version installed.
Old Jan 21, 2010 | 09:24 AM
MUDSTROKIN''s Avatar
Sounds like it could be the ICP sensor, HPOP (High Pressure Oil Pump) - Fire the injectors, FICM (Fuel Injector Control Module), or injectors alone....
Old Jan 21, 2010 | 05:50 PM
brando's Avatar
Where's the ICP located on that truck? Also not sure if it's like the 7.3 but could there be a loose connection on one of the UVC's? Thanks again.
Old Jan 23, 2010 | 10:32 AM
Mdub707's Avatar
Need more info on this.. is it throwing any codes at all?
Old Jan 23, 2010 | 01:12 PM
blackbomber's Avatar
I think if it was the hpop it wouldnt even fire. i think (just went though that)
Old Jan 24, 2010 | 08:34 PM
brando's Avatar
He said it has not run a code.
