1st gen chassis splice
Old Jan 20, 2010 | 06:59 PM
bowdiesel's Avatar
Default 1st gen chassis splice
anyone out there ever splice on a new rear chassis....?????? I'm looking to do from the start of the bed just under the end of the ext cab where its all remarkably still good steel but from the bed back...I think one of the previous owners used it for salting so its probably only got a year or 2 left ...I had to change the rear leaf hangers on both sides this fall already and the tank straps are letting go.....The front is still very solid.. night and day to the rear ...and I did a ton of front end work and steering mods to tighten her up the ..5.9 12v was rebuilt @ 137k and it now has 155kthe body's still sharp///// new 32's on factory rims off a 96 W/ 2" SPACERS so she is now a keeper .....So anyone's got a 1st gen 93 w250 ext cab with a good rear frame give me a shout .....if you got one im coming .... ILL DRIVE TO IOWA ,ILLINOIS ,KANSAS , . DURING hunting season...THE TRUCKS CHASSIS CAN HANDLE 1 MORE GOOD ROAD TRIPP
Old Jan 20, 2010 | 07:34 PM
RSWORDS's Avatar
Never done a 3/4 ton truck but here is my old Yota that I fixed.
Yota Frame Fix... - Pirate4x4.Com Bulletin Board
Old Jan 20, 2010 | 09:15 PM
tltruckparts's Avatar
its pretty easy if your good with a torch and welder. just takes time and precision to do it right
Old Jan 20, 2010 | 09:19 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
it can be done
Old Jan 20, 2010 | 10:04 PM
freak007's Avatar
I will have a frame that you can have hopefully this spring/summer... It will be in northern MN and have no driveline (including axles)....
Old Jan 20, 2010 | 10:13 PM
440warwagon's Avatar
I just looked at a 92ish W250 std cab cummins truck minus the engine on "racing junk.com.
Old Jan 21, 2010 | 04:07 PM
bowdiesel's Avatar
will keep you in mind ...but hope to find one before spring.... if not hows the fishing up there????
Old Jan 21, 2010 | 04:43 PM
TTipsword's Avatar
Frame work is easy. just make sure you measure, measure again and again. then repeat the process. i spliced a bel air frame to the sup frame of a camero in high school. well is somethin along those lines. if i can do it you can do it.
Old Jan 21, 2010 | 04:54 PM
Whit's Avatar
Site Mascot
as long as you are good at fab work and welding verticle and overhead it will be OK...............its actually a fun job, I would weld the frame then fish plate inside and out if possible
Old Jan 21, 2010 | 05:55 PM
bowdiesel's Avatar
KEEP THE TIPS ROLLING IN ...I AM SOAKING THEM ALL IN.......GOT( A -PLUS) WELDER TO HELP ME.... WITH ALL THE EQUIPMENT AND SHOP ...HE IS A DODGE GUY AND HE ACTUALLY CANT WAIT TO DO IT..AND HE'S DONE A FEW ALREADY.. JUST GOT TO FIND THE DAM CHASSIS....ANYONE NO IF ANYTHING OTHER THAN 88-93 CHASSIS ARE A MATCH TO A 93 W250 EXT CAB 8' bed....do w350's match or do gas frames match the deisel....many more gas frames out there being parted out ......
