Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
U Joints
Old Jan 20, 2010 | 02:23 PM
DIRTYMAX2004's Avatar
Default U Joints
hey guys i was just wondering who makes a good U Joint. I go through u joints like candy and i havent found anything that will hold up to turning the 35" tires on my truck.
Any suggestions?
Old Jan 20, 2010 | 02:39 PM
2500HeavyDuty's Avatar
does your truck have a two piece drive shaft, how are the angles on them, maybe theres a shim missing on the carrier bearing, if they are off it can really trash u joints
Old Jan 20, 2010 | 03:18 PM
yes it does have a two piece. . . i only have a problem with the one that connects to the rear end. . . i had the angles checked when i put the lift in and they said it was good to go. . . i have the biggest problems when i pull a trailer or go on really long road trips.
Old Jan 23, 2010 | 11:38 PM
jlawles2's Avatar
You could have a bad case of axle wrap. How much lift do you have and is it by springs or blocks?
Old Jan 24, 2010 | 07:58 AM
4" LIFT BLOCKS
wildbill
Oct 2, 2015 01:56 AM
LawdawgSHPD
Aug 21, 2015 06:23 PM
CumminsCoalRoller24/7
Jul 5, 2015 06:30 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
