Installed a new Belt... Squeaks like crazy now~!
Old Jan 20, 2010 | 01:48 PM
usmcbay's Avatar
Default Installed a new Belt... Squeaks like crazy now~!
Anyone ever had a squeaking belt that wouldn't stop... Its on correct. I've Degreased it, Washed it, Belt dressing a little, Belt Dressing a lot... it's driving me mad!
Any suggestions?
Old Jan 20, 2010 | 01:51 PM
blkjack's Avatar
try sprayin a little WD-40 on it sometimes that seems to help have done that alot on belts helps alot better than the belt dressing the dressing seems to just gunk stuff up. Give the WD-40 a shot may work for ya
Old Jan 20, 2010 | 02:16 PM
usmcbay's Avatar
At this point I'm willing to try anything - legal or otherwise~!
Old Jan 20, 2010 | 02:21 PM
2500HeavyDuty's Avatar
is a serpentine belt?
Old Jan 20, 2010 | 02:25 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/5-9-li...ight=fan+belts try some of these ideas
Old Jan 20, 2010 | 04:50 PM
usmcbay's Avatar
Yep... put the WD-40 on - Got worse...
Old Jan 20, 2010 | 08:26 PM
dangerous1965's Avatar
What brand belt did you buy? The cheap crap belts do this! Try a gator back or Cummins belt! The WD-40 Just makes it slippery for a while then it's back Try a can of brake clean to clean it off then try to see if it's the belt or a bearing going bad. Take the belt of and spin everything see if something hangs up or is rough everything should turn smoothly!
Old Jan 21, 2010 | 08:43 AM
usmcbay's Avatar
At this point there is a chemical cocktail on the belt... I will Degrease it again and try the Brake Cleaner. I think Electrical cleaner works the same. I even thought about strategically placing a little sand on the belt to try to scuff it a bit...
Old Jan 21, 2010 | 09:08 AM
Please read my post and answer my questions and try what I asked. Don't put sand on it! That will just find it's way to your bearings! No worries!
Old Jan 21, 2010 | 12:00 PM
Uncle Bubba's Avatar
Simple stuff here. You have a bearing goin bad in somethin. The old belt was stretched enough that it didn't put any tension on the bad pulley and now that it's a new belt it's puttin tension on it again. I've always found the simplest way to find the bad bearing is with those stupid little $2 mechanic stethoscopes. Withe truck runnin, very carefully work the probed from pulley to pulley, when you find the right one you'll know, no guessin required.
