4x4 problems
Old Jan 20, 2010 | 12:36 PM
nate379's Avatar
Default 4x4 problems
98 Dodge 2500.
I can't get it in 4x4 unless I am stopped or at a crawl.
If I try to shift it doing let's say 30-40mph it normally won't go in, just will grind.
This doesn't seem normal and is a hassle when I hit icy roads and have to pull over to get it in 4x4.
Any thoughts on what I need to look at?? This a problem for anyone else?
My theory is because the front driveline isn't turning in 2wd, I'm not able to sync together the rear and front while I'm moving.
Old Jan 20, 2010 | 12:53 PM
12vcummins96's Avatar
no you cant put it in 4x4 while rollin only if its on demand 4x4 can you do that you will just have to continue the way you are doing it
Old Jan 20, 2010 | 05:55 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
I can put mine into 4x4 while im going up to 50mph... Are you sporting different front and rear size tires? Any large change in driveline speed from front to back is bad! Like smaller tires in front vs back... Thats also epically bad for your xfer case too!
Old Jan 20, 2010 | 06:17 PM
Ed ke6bnl's Avatar
Hope we r talking about 4x4 HIGH ED
Old Jan 20, 2010 | 06:31 PM
cummins24's Avatar
I can go into 4HI while rolling no problem, but I never do it going more then about 20-25mph
Old Jan 20, 2010 | 08:47 PM
nate379's Avatar
Nope, same size
haha... would be interesting trying to do 65-70mph in low range, that's for sure!
Old Jan 20, 2010 | 09:17 PM
captain_stabbin's Avatar
if it were me, i would stop just cause i wouldnt wanna mess sumthin up!
Old Jan 21, 2010 | 12:05 AM
MUDDY's Avatar
vacumn leak or prob with the vacumn acuator in the front axle housing which slides the collar to connect the split front axle shafts together. and as you mentioned the fact that the front drive shaft is not turning also contributes to difficulty even when it is working as it should be.
my choice is to remove the vac acuation garbage.
Old Jan 21, 2010 | 12:11 AM
MUDDY's Avatar
4x4 Posi-Lok - 4WD Engagement Systems
check that out nate. tis what i put on my 98.5
also offers a 2wd low range for backing trailers.
Uncle Bubba's Avatar
I'm with Muddy, it sounds like a vacuum leak or the pump gettin weak. I drop mine in and out all the time sloppin through the mud no problem at all.
Only time I had any problems was when the selector lever had to be adjusted cause the bolt that connected to the transfer case came lose.
