tach
Old Jan 20, 2010 | 11:10 AM
91 12valve's Avatar
Default tach
what is the best tach to get or does somebody make a kit for a first gen cummins
Old Jan 20, 2010 | 12:05 PM
FastCR's Avatar
i don't recall the cutoff year that has the factory hookup, but autometer, isspro, or tinytach are the popular options.
Old Jan 20, 2010 | 05:09 PM
butcherman's Avatar
Where would you find the factory hookup if you had one?
Old Jan 20, 2010 | 08:28 PM
FastCR's Avatar
somewhere above the steering column i think. Hopefully a 1st gen guy will chime in, I've only read about it.
Old Jan 20, 2010 | 09:07 PM
921stgen's Avatar
If you have a 89-91 you can use the Isspro tach that uses a magnetic crank sensor, both of the next 2 threads have that info. Isspro part numbers for tach - Dodge Cummins Diesel Forum In post #15 shows a pic of a tach hooked up to an alternator. how do wire in a tach in a 91 - Dodge Cummins Diesel Forum More info on the early dodge tach setups. https://www.dieselbombers.com/5-9l-r...uge-mount.html In this thread is a pic of the factory tach plug in post #5 at bottom in center of pic its black, installed in the 92-93 trucks. http://www.dieseltruckresource.com/d...t=factory+tach Heres some info on installing the tach in a 93 dodge with the factory tach plug. http://www.dieseltruckresource.com/d....html?t=173561 Heres another option. http://www.dieseltruckresource.com/d....html?t=236340
lvnlrge63
Aug 10, 2015 06:39 AM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
gp98
Apr 1, 2015 07:08 AM
short12
Jan 2, 2015 04:56 PM
