SMARTY Programmer S-03 REVO, 98.5-02 Dodge
Old Jan 20, 2010 | 10:26 AM
Joe Diesel's Avatar
Arrow SMARTY Programmer S-03 REVO, 98.5-02 Dodge
I'm selling my SMARTY with REVO programmer, I've had it for a about a year works great the upper levels no timing give a serious acceleration off the line. It has the new REVO download. Comes with case programmer instructions and cable. Im selling for $550 plus
shipping. I take paypal. Any questions PM me thx.
from website:
Fast guide to Smarty's special Features
CaTCHER software's inside
Ten different performance levels
Fastest download in the industry, a typical ECM update takes
less than two minutes
ABS tire height updates in just seconds
Not traceable in the stock setting. Smarty leaves no footprint
Cold weather 3 Cylinder High Idle is enabled in all softwares
Reads Diagnostic Trouble Codes in plain text
No tools required, no fuses to pull
USB built in for simple updates
Most complete keyboard in the industry
Reliable, it works off your OEM hardware
Programmable Speed Limiter from 25 to 250 mph (in trucks of 2001
and 2002 the speed limiter is programmable in mph, older trucks have only a speed
adjustment)
Fast guide to Smarty's softwares levels
SW# 0 : Half power .
SW# 1 : Fuel Saver
SW# 2 : Only more fuel and Boost fooling
SW# 3 : Like # 2 + added timing
SW# 4 : “Soft” CaTCHER no added timing
SW# 5 : Like # 4 + added Timing
SW# 6 : Mild CaTCHER no added timing
SW# 7 : Like # 6 + added Timing
SW# 8 : CaTCHER no added timing
SW # 9 : CaTCHER with Timing
Software number Zero,
About half the power of a stock software. Use it whenever reduced power is
desired or when you have to make sure that NO SMOKE is produced .
Software number One,
The Fuel Saver software. Mpg gains vary, in most cases a + 2Mpg has been
reported.
Please notice that the timing in this software is rather aggressive.
HEAVY TOWING is not recommended with this software.
Software number Two,
This software increases the fuel delivered by the ECM and does the boost fooling.
Software number :Three,
Same as software # 2 but timing has been added.
CaTCHER softwares from number : Four to number Nine,
The even numbered softwares are identical to the odd numbered ones, except for
the timing. The softwares without added timing are intended for use with timing
adding boxes.
The power gain at top Rpm with these softwares is almost identical. These
softwares differ greatly in HOW they get there. Than higher the software number
then more aggressive the throttle response from idle speed up. Aggressive to
the point that the softwares Eight and Nine can become difficult to handle on
slippery roads. Please be very careful when you use these softwares for the first
time! It takes some time to learn how to handle them.
REVO program
The items are :
Speed-limiter
Torque Management levels
Injection timing
Injection duration
The levels are :
Speed-limiter
From 25 to 250 mph in one mile increments
Torque Management
# 0 - Default
# 1 - Stock
# 2 - Mild
# 3
# 4 Moderate
# 5
# 6 - Wild ( aftermarket clutch / AT Transmission recommended )
Injection Timing
# 0 - Default
# 1 - Stock
# 2 - for stock injectors
# 3 - for aftermarket Injectors
# 4 - for fuel economy
Injection duration
# 0 - Default
# 1 - Stock
# 2 - Mild
# 3
# 4
# 5 - Long
The above descriptions are for the REVO standard software.
Old Jan 20, 2010 | 02:20 PM
cummins-dodge's Avatar
do you still have the smarty could you email me at cummins-dodge@hotmail.com
Old Jan 20, 2010 | 02:44 PM
Joe Diesel's Avatar
email sent
thatdude38
Aug 31, 2015 05:22 PM
Josh_L
Apr 12, 2015 12:12 PM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
