Altenator Voltage or Transmission??
Old Jan 19, 2010 | 10:16 PM
Suprdave67's Avatar
Default Altenator Voltage or Transmission??
Today my pickup started some funky stuff. It stifted down and up a few time and finally stayed in the low gear and at the same time the tacometer was bouncing back and forth with the check engine light and generator light flashing . When I got back home and restarted it the the voltage gauge wouldn't show any output and when I would take off it seem to be in 2nd gear . Thats the simtumes here the question, if the altenator goes out would it screw with the way it shift? I thought transmission at first but when you add in the tac and volt gauge thats when I got confused. Any suggestions would be greatJ I figure I would start with checking the altenator output .
Old Jan 20, 2010 | 07:29 AM
PhilipR's Avatar
Check the CPS sensor on the front of the engine.....if it's not right the PCM doesn't know the truck is running. The gap should be .050" from the balancer and check the wiring coming from it. If that all checks out okay next stop is the PCM.
Old Jan 20, 2010 | 11:03 AM
Suprdave67's Avatar
Thanks Duster, I will check that out this morning. Because when I went to start it this morning Tac is working and volt gauge too. So I know its electric..
Old Jan 20, 2010 | 11:09 AM
PSD's Avatar
PSD
The high voltage regulator on my alternator broke, so my batteries were not charging. I did not know that it had broke, but once my truck started acting funny, I guessed it was from when a buddy of mine was under the hood doing some turbo work for me. I was able to ride around for a couple of days on the battery life, but when it got low, she started to shift oddly and the tac also jumped around. After losing everything like gauges, radio, lights, the truck died infront of my buddies house haha
Old Jan 20, 2010 | 04:03 PM
Suprdave67's Avatar
Thank guys!!! It ended up bring a wiring on the altenator it was loose, but I still think its going out. At least it wasn't something major. If it goes out no big deal because I want to put a 100amp on it anyway.. Thanks again for the info...
Old Jan 20, 2010 | 04:30 PM
PSD's Avatar
PSD
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
