Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
2.6 class
Old Jan 19, 2010 | 09:53 PM
hunter's Avatar
Default 2.6 class
hey guys,wanting to pull 2.6 this year wanderin what kind of set up u guys are running and what i can expect to get into im bout to upgrade clutch but every thing else is in my sig,any advice will help,thanks
Old Jan 20, 2010 | 04:33 PM
94 12valve's Avatar
By clutch I hope you mean a dual disk, I'm running a 3850 12 button south bend in my truck. You will also want to upgrade your input shaft because they break easy ( you will have to if you put a dual disk in). You will also need a set of traction bars and bump stops.
If you want to pull the 2.6 class you will need to go bigger than that 62mm charger.
Old Jan 20, 2010 | 07:10 PM
NOfullpullEL's Avatar
Better upgrade that p-pump to a 13mm. bigger charger,cam balance the engine because u need to spin it 5000+ rpms change the gears to 4.88 or 5.13, head work,. That might get you a top five truck. All yea drive the hell out of it too!
Old Jan 20, 2010 | 08:15 PM
RSWORDS's Avatar
yeah guys are taking 2.6 way more serious.... Spending CRAZY money, but it all depends on were you location is. We have a 2.8 class here thats a joke...
Old Jan 21, 2010 | 11:50 AM
hunter's Avatar
it needs to be semi streetable so 4.10s will have to do
and im looking at an s400
Old Jan 21, 2010 | 03:26 PM
The 2.6 points champion around here is real close to 900hp so i would say its pretty serious. All the contedors around Central OHIO have built engines that cost in the 20 to 30 thousand dollar range!
Old Jan 21, 2010 | 04:31 PM
94 12valve's Avatar
if 4.10's is as big as you can go I would stay with your 3.54's and pull in 3rd low and put a set of 5k springs in there.
edit - if you can't turn over 4k then I would still keep the 3.54's and run 2nd high
Last edited by 94 12valve; Jan 21, 2010 at 04:31 PM. Reason: Automerged Doublepost
Old Jan 22, 2010 | 09:53 AM
hunter's Avatar
yeah i cant afford the bulit engine and make payments on my other truck so im gona stay small but im forced into the 2.6 class cause of my turbo,so i mite as well upgrade to s400 and maybe change the gears not quite sure yet thanks for the advice keep it comeing
Old Jan 22, 2010 | 02:46 PM
94 12valve's Avatar
If your just starting out there is no need for a 13mm pump, your stock ppump will do just fine.
You should how ever add a 5k gsk, full cuts,5x16's, and a bigger turbo
Old Jan 22, 2010 | 03:28 PM
hunter's Avatar
i was thinking of the haisely street puller cam as well,since im fire ringing and studing my head anything else
