coolant leak from front
Old Jan 19, 2010 | 07:18 PM
spokes's Avatar
Default coolant leak from front
I have a 03 f350 6.0l with 225000km have done egr deleat,oil cooler, and i think i was called inj.cups ( had diesel in my coolant ). Now again i have a coolant leak, i crawled under and looked up at the front of the motor and seen it running down the front. I am still getting coolant that still has an odor of diesel blowing out the cap of the degas bottle. Any guesses to what i could try and look at or check?
Old Jan 19, 2010 | 09:31 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and its not the weep hole on the water pump by chance thats leaking is it hopefully somebody else will speakup on here too
Old Jan 19, 2010 | 11:33 PM
Mdub707's Avatar
If it's blowing out the degas cap, and you've already got an EGR delete.... it's probably the headgaskets...
Old Jan 19, 2010 | 11:48 PM
spokes's Avatar
When the head gaskets go do they not usually leak coolant into the engine?
I thought that I read somewhere on this site that a person may still get coolant blowing out the degas cap with the egr deleat
Old Jan 20, 2010 | 05:07 AM
KLOVE's Avatar
check your top tank on the radaitor the seals are leaking on mine
Old Jan 20, 2010 | 11:11 AM
Mdub707's Avatar
Well when the headgaskets go the cylinders will over-pressurize the coolant system and force coolant out the degas cap, then when you shut the truck off, the coolant system is now pressurized and the cylinders have nothing, so now the coolant is pushed back into the cylinders. This obviously isn't the only scenario to show you have blown headgaskets. I had a buddies truck do this though, and it was a bear to start in the mornings because of the coolant in the cylinders. It eventually got so bad that the valve guides corroded and valves started sticking and made contact with the pistons. It was a complete mess. It broke rocker arms and destroyed a cylinder/piston. This is obviously a worst case scenario, from someone who let it go for too long without fixing the leaky headgaskets.
To answer your second question... there are guys with headstuds/new gaskets and EGR deletes that still have coolant puking out...
Old Jan 20, 2010 | 12:53 PM
HeavyAssault's Avatar
If you place a pot of water on a stove, cover it with a lid and turn the heat on HIGH what happens? Why do you think your coolant is any different?
Check the T-stat housing....
Old Jan 22, 2010 | 07:35 PM
spokes's Avatar
leak was comming from o-ring in the oil cooler. Looks like i still have diesel going into my coolant, caused the oring to swell up and become soft.I must still be getting diesel into the coolant from a cracked head Thats my only guess............
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
crayons
Mar 20, 2015 03:50 PM
Mike0885
Feb 28, 2015 03:16 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
