Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
Turbo Vanes stuck
Old Jan 18, 2010 | 08:21 PM
greenbomb's Avatar
Default Turbo Vanes stuck
Someone in one of the posts was talking about the turbo vanes getting stuck if the truck was not operated much. How can you tell if they are stuck and how do you unstick them?
Old Jan 18, 2010 | 08:31 PM
motoxracer42's Avatar
you will notice is in boost and power. sometimes they get stuck shut sometimes open. you fix it by taking the turbo out and cleaning them.
Old Jan 18, 2010 | 09:58 PM
2500HeavyDuty's Avatar
the spool up will be very slow, and peak boost will take a hit too
Old Jan 19, 2010 | 07:06 AM
Rttoys's Avatar
It can also throw a code for incorrect vein position.
Old Jan 19, 2010 | 06:58 PM
greenbomb's Avatar
Default turbo vanes stuck
Thanks guys
I ordered a code reader from one of our sponsers and I will check for codes when it comes in. What I was really hoping is that you would say spray some carb cleaner or WD40 in the intake and all would be OK
Old Jan 19, 2010 | 07:13 PM
Originally Posted by greenbomb
Thanks guys
nope that wouldnt help, the vaines are on the exhaust side of the turbine housing
Old Jan 19, 2010 | 07:54 PM
Rttoys's Avatar
Thanks guys
If you ever want to see a 'run away' engine, spray carb cleaner in the intake. Then after it shells out a piston through the side of the block, you get a chance to drop in a nice new engine.
Old Jan 19, 2010 | 07:55 PM
i did that on accident once i was lazy and didnt feel like pulling my MAF sensor out to clean it, just sprayed the cleaner in there and there was quite a bit of residue left.... turned the truck on and kaboom
Old Jan 19, 2010 | 08:47 PM
jbrown1132's Avatar
that would be a true bomb
Old Jan 24, 2010 | 09:53 PM
greenbomb's Avatar
Thanks for the cleaner warning . Anyone ever remove on of these things for cleaning?
Seems like quite a job
