changing dv
Old Jan 18, 2010 | 06:35 PM
bowtech's Avatar
Default changing dv
any tricks to it or just unscrew the line off and take old one out put in the 180?
Old Jan 18, 2010 | 06:54 PM
Benjamin's Avatar
Bombardier
take the injection lines completely off the motor, use a delivery valve socket to remove the thing that holds the delivery valve and holder in place. then use a magnet to remove the delivery valve and holder, make sure to remove all shims if any that were under the delivery valve. install the 181's replace the o-ring on the pump with the one that came with the new delivery valves, and tighten the cap back down to a specific ft/lbs (not sure, mine are "tight") and then install the injection lines and bust her off to find your new found power.
Old Jan 18, 2010 | 08:05 PM
bowtech's Avatar
im going to be geting a set of 180 to replace my 130 what the power diff going to be? im buying used dv on here where i get new o rings?
Old Jan 18, 2010 | 08:08 PM
Benjamin's Avatar
Bombardier
you are removing 131's not 130's and installing 181's not 180's. it will be stamped on the delivery valve head what number it is.
you can get the oring from any truck shop that does fleet work on big rigs, just make sure you can explain what you need to them and they understand.
Old Jan 18, 2010 | 08:15 PM
bowtech's Avatar
ok. so what are the power gain going to be like?
Old Jan 18, 2010 | 08:20 PM
Benjamin's Avatar
Bombardier
it will be pretty substantial. the 131's choke the fuel down alot. watch the pyro and you will see it move faster along with more boost and the truck should haul fairly good. i'm not sure how the PI injectors will do as i don't have first hand experience with them but have rarely heard any good or bad.
it will more than likely be more fuel than the stock turbo can suply air for depending on where the #5 fuel plate is positioned. it will also more than likely over power the stock converter (i see a V/B but no converter in your sig) so it's lifespan will suffer....
i don't want to say any HP numbers you will gain as all trucks are different.... but it will be noticeable if you put the truck on the butt-dyno....
Old Jan 18, 2010 | 08:31 PM
bowtech's Avatar
the 5 plate is in the middle so on the stock turbo with the boost elbow wont be able to keep up? im going to be geting a tc after tax return
Old Jan 19, 2010 | 05:22 AM
wes-cummins's Avatar
turbo wont beable to keep up with injectors and dvs, get a triple disk tc
Old Jan 19, 2010 | 01:37 PM
Smokem's Avatar
The shoulder is smaller on the 131 than the 181, which means when comparing the valves themselves, the 131 would flow more fuel. Take a look at the difference in the seat, then you may be on to something. Tried them every which way, not much power difference between any version.
Old Jan 19, 2010 | 03:00 PM
BigDiesel359's Avatar
So there isn't much difference between a 131 and a 181? How about a 191?
