loss of power
Old Jan 18, 2010 | 05:52 PM
eric guerin's Avatar
Default loss of power
I own a 2005 powerstroke and I was driving today and lost power the factory boost gauge went to 0, I tried to accelerate had very little power, a few minutes later i got boost and now its fine. What could it be? Does the turbo lose boost if the EGR is plugged?
Old Jan 18, 2010 | 08:20 PM
motoxracer42's Avatar
could be the egr. could be the veins in the turbo sticking. i would say turbo problems. ford updated them last year so they dont have as many problems. probably take it apart and clean the veins.
Old Jan 19, 2010 | 03:36 PM
crewed powerstroke's Avatar
Sounds like a turbo issue. The vanes are known to get dirty, then stick. If the vehicle is still under warranty , it would be worth the $100 deductable, if not it there is lots of info that can be found on these threads that can help you out, or just ask lots of questions and we'll try to help the best we can.
Oh; by the way I think you will like it here!
Old Jan 19, 2010 | 04:40 PM
I have a 1704 MAX Micro Tuner on it i wonder if that will void my warranty on it. By the way thanks for the info.
Old Jan 20, 2010 | 02:54 PM
How does it run without the tuner? Same issue? If you start reading lots of these threads; tho ONLY tuner that is almost always recommended for a 6.0 is SCT with custom tunes. It should not void the warranty (Mod friendly dealer of course), however before you take it for service be sure to return it back to stock, just incase it would happen to get reflashed. Also does your tuner pull any trouble codes? If so what codes do you have?
Old Jan 21, 2010 | 03:01 PM
I have checked it is not throwing any trouble codes
I called the dealer my warranty is up in March and they said Ford will not cover the turbo until it goes out completely, that really sucks. It hasnt messed up since the other day but im sure the problems are coming, but they are gonna look at my EGR cooler I think its bad..
Last edited by eric guerin; Jan 21, 2010 at 05:55 PM. Reason: Automerged Doublepost
Old Jan 21, 2010 | 05:27 PM
Are you loosing any coolant? Does it blow any smoke until it warms up?
Old Jan 21, 2010 | 05:49 PM
The coolant is low but I havent had to add any since I bought it 2 years ago its went low in the past couple of months, it has always blown smoke till it warms up. But I did notice a couple of weeks ago i had been driving about an hour when I notice steam rolling out the exhaust when I was accelerating then it quit a few minutes later.
Old Jan 21, 2010 | 05:52 PM
Please post up what you find out at the dealer. I think my nephew is having a very similar issue.
Old Jan 22, 2010 | 03:21 PM
I will hope they treat me rite.
