selector switch
Old Jan 17, 2010 | 10:49 PM
94cummins12v's Avatar
Default selector switch
i was wondering if the 91 ford with the 7.3l in it had a return line. what im wonderin is i know the selector valve for the fuel tank controlled the eturn line also?
Old Jan 18, 2010 | 12:06 PM
Sycostang67's Avatar
It would have a return line, not sure if/how it interacted with the selector valve though.
Old Jan 18, 2010 | 09:43 PM
Dinodidit's Avatar
On my 85 w/6.9l the selector valve changes both the feed and return lines. It is located under the cab and has 6 lines to it. If there are only 3 then most likely not. Hope this helps.
Old Jan 18, 2010 | 09:46 PM
ya thanks helps alot i know i need the return ine since im mounting my cummins in it
Old Jan 19, 2010 | 07:49 AM
Dinodidit's Avatar
Glad to help good luck.
