Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Water / Methanol
Old Mar 14, 2007 | 09:44 PM
Dr.Automotive's Avatar
BANNED CROOK
Default Water / Methanol
Anyone using or tried water/meth to control egt's ?
Old Mar 14, 2007 | 09:47 PM
JON's Avatar
JON
Member
Default Dont know much
about it. But I really want it. I hope someone comes along that knows about it.
Old Mar 14, 2007 | 09:51 PM
BANNED CROOK
I run it, have had good results
Old Mar 15, 2007 | 12:14 PM
Oregonpharmer's Avatar
I have used water/methanol for years. But have been running into oil contamination problems with the new ultralow sulphur diesel. Some of the new diesel contains a significant amount of water in the fuel, and uses some exotic alcohol to keep the water in suspension. As soon as I start injecting my water/methanol with that fuel the power drops, so it is easy to spot when you get a tank. Just turn off the water system until you run it out, then try the next tank.
It does not seem to be isolated to any particular brand, but Citgo seems to always cause a problem.
Old Mar 17, 2007 | 01:24 PM
RAT_03's Avatar
What is about the best kit out there?
I would like to run a kit as well
Old Mar 18, 2007 | 07:52 PM
greyghost2's Avatar
Yeah count me in on the kit Ideas I was also looking at propane kits but haven't looked at all the + and -'s of both
Old Mar 19, 2007 | 08:20 AM
wrglrroper's Avatar
Me to greyghost. I am one fo those do it yourselfers so I am going to try and make it by pieces.
Usually ends up costing me more in the long run though.
Old Mar 21, 2007 | 12:43 PM
wrglrroper's Avatar
Hey Dr. A,
Can you get use just nossels and maybe hose if we are wanting to try and make Water/Meth ourselves?
Old Mar 21, 2007 | 10:18 PM
BBD's Avatar
BBD
IMO the best kits are here:
http://www.snowperformance.net/
BBD
Old Mar 21, 2007 | 11:55 PM
IC Smoke's Avatar
660 on snows kit for a stage 3
Im in the process of installing mine (stage 3) at the moment, Its going to run off my washer fluid tank so i have a nice "alarm" when im low
Ian
