leaking some fuel
Old Jan 17, 2010 | 12:11 PM
luke46's Avatar
Default leaking some fuel
So I started smelling fuel and saw a small puddle Got to looking once I drove it home and it is dripping off the bottom of the vp44 out back toward where the lines come out. I can't tell exactly where because It's kind of crowded back there. But it feels like it's coming off the bottom of the pump. Truck still runs and starts great Checked all my lines they are good and tight. Is there anything else I should try. Can I buy one of those ebay seal kits and fix it or am I screwed??
Old Jan 17, 2010 | 12:17 PM
Uncle Bubba's Avatar
Check the lines up by the injectors to see if it's running downhill from one of them. Sometimes if the seal isn't exactly lined up the compression fitting can leak a little even if they are tight.
Are all the little blue connectors still in place and in the right places on the fuel lines.
Old Jan 17, 2010 | 01:26 PM
dukeboy_318's Avatar
i had the return line on mine corrode through and make a pin hole enough to cause it to leak, maybe its happened to yours too
Old Jan 17, 2010 | 02:09 PM
luke46's Avatar
Ya there isn't any fuel running down the lines that's the first thing I checked since I ha djust done the injectors about a month ago. As for the return line I looked it over pretty good and can't find anything.
Old Jan 17, 2010 | 03:10 PM
if you just installed injectors, i bet uncle bubba's right, the crush washer didnt seat properly
Old Jan 17, 2010 | 08:28 PM
luke46's Avatar
I didn't undo any lines at the pump just undid all the mounts and where they go into the crossover tubes
Dbleo351
Nov 20, 2016 09:34 AM
Excursion73
Ford Excursion 99-05 7.3L and 6.0L
Aug 29, 2015 05:52 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
WickedEvo
Oct 20, 2014 10:50 PM
