Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
south bend 3600 DD street comp?
Old Jan 17, 2010 | 03:06 AM
smokin' goat '01's Avatar
Default south bend 3600 DD street comp?
Hey guys, I've been around a pulling track almost all of my life but I'm gonna try my hand at it for the first time this year. I've got everything I need except for a clutch. I'm looking at a south bend 3600 DD street comp 12 ceramic button. Is this a good enough clutch for a couple hooks a year? My truck is a daily driver so I not only want a clutch that holds on the track but is also still very streetable. Anyone running the 3600? Any input will be appreciated...thanks guys
Old Jan 17, 2010 | 09:47 AM
Pack Mule's Avatar
i daily drove, pulled, and drag raced a 3850DD without a problem at all. wish i'd have gotten the iron giant. so the 3600 will not be difficult to keep on the street.
Old Jan 17, 2010 | 11:40 AM
Thanks for your help. Did you run the sprung or rigid setup? Also, how many hooks did you put on the 3850 and what class? I'm just wanting to run a few local pulls in the street classes
Old Jan 17, 2010 | 06:46 PM
R&RDiesel's Avatar
FormerVendor
If you are going to pull several times a rear i would run the 3850, sprung hub is what i would recomend. The 3600 wont like the pulling track too many times.
Old Jan 17, 2010 | 07:17 PM
I have several customers running a 3650# Valair DD for there part time pullers.
Old Jan 17, 2010 | 09:25 PM
LawnScum's Avatar
i have the street dual disc 3250. in my 02 24valve and i love it. didnt have to replace the hydros and the pedel is softer then stock. its a little grabby. but its a great clutch i sled pull with mine and never spun it. not sure about the clutch your talking about, mine was 1100$ and its the best investment ive made to the truck
Old Jan 18, 2010 | 07:23 AM
Hummin Cummins's Avatar
I run a 3600 hub sprung 12 button clutch. I have over 30 hooks boosted launches in 4th gear to it. Ended up with 28 wins.
I do a lot of heavy towing and it has been a good clutch I have a little over 70,000 on it.
I know a guy that is/was running a 2001 P-pumped 24 valve that has dynoed 1000 hp and he run a 3600 for a year sled pulling.
Old Jan 18, 2010 | 09:38 AM
Thats somewhat interesting but the original poster was asking about a Southbend clutch. Lets stay on topic and limit discussion to Southbend.
Old Jan 18, 2010 | 02:26 PM
Wow! 1000hp for a year pulling? That's impressive! I'm torn between the 3850 and 3600...my cousin told me that the rigid would be better for pulling. What's the difference in sprung and rigid? Is the rigid streetable?
Old Jan 18, 2010 | 06:27 PM
R&RDiesel's Avatar
FormerVendor
The sprung hub has heavy springs in the the hub, to quite the clutch down and make it smoother, the rigid is just what it says no springs, you can street a rigid clutch.
