block heater
Old Jan 17, 2010 | 12:40 AM
stevenbrazell's Avatar
Default block heater
hey yall, is it possible to install a engine heater on a truck that did not origanally come with one from the factory. im looking at a 99 cummins and wondering if it'd be possible.
Old Jan 17, 2010 | 12:43 AM
They ALL came with a block heater (unless the engine has been rebuilt and the block heater eliminated). It should also have a cord which is probably rolled up somewhere on the passenger side. The block heater should be on the block just behind the oil filter.
Old Jan 17, 2010 | 12:59 AM
dukeboy_318's Avatar
agreed, ive never seen a 99 without one personally, like doc says, it should be located under the oil filter on the passenger side of the block,
Old Jan 17, 2010 | 07:54 PM
RAW's Avatar
RAW
If not, I would not waste time pulling a expansion plug and putting an element in. Instead I highly recommend a circulating block heater, they do a excellent job!! If you can justify the cost, or just have extra cash kicking around (ha, ha), put a Webasto or Espar on your rig. They use diesel fuel to heat your coolant, no 110 power needed, and draws very little from you 12V system.
Old Jan 17, 2010 | 08:02 PM
Yeah, Ive got an Espar - works like a charm....
Hard to justify the cost of an Espar for the original poster - hes from Texas.
Old Jan 17, 2010 | 08:18 PM
RAW's Avatar
RAW
That is very true, up here in Central Alberta Canada, I am starting to justify it more and more. Turbo, or Espar?
Old Jan 17, 2010 | 10:28 PM
Espar definitely. Theres nothing like never having to scrape your windows, never having cold starts on the engine and jumping into an already warm truck when its -30C
Old Jan 17, 2010 | 10:29 PM
RAW's Avatar
RAW
I hear that! A co-worker has one, and rubs it in my face. Maybe soon, very soon.
Old Jan 19, 2010 | 01:11 PM
Joe Diesel's Avatar
so whats the cost of one of these Espar units?
Old Jan 19, 2010 | 01:19 PM
$1000+ (And that doesnt include install). But the install is quite straightforward.
I can probably put you in touch with a guy in Red Deer that works for Polar Mobility.
