afc ?
Old Jan 16, 2010 | 02:19 PM
wes-cummins's Avatar
Default afc ?
hey i got my afc off and took it apart to make some changes, i took the adapter fitting for turbo boost to put shop air to it? i noticed that the adapter fitting had a snubber in it, or a very small hole in it, does any one know if drilling the hole out would allow it to see boost faster? would it help?
Old Jan 16, 2010 | 05:15 PM
monster12valve's Avatar
no.. the smaller hole the more boost. some people plug the line off.
Old Jan 16, 2010 | 05:21 PM
lodal cummins's Avatar
why is it then when you buy a fuel plate the boost elbow they send you has such a big opening?
Old Jan 16, 2010 | 08:32 PM
im talking about the brass fitting that goes into the afc housing for the diaphram.
any way i drilled it out and i noticed a little bit of a diff in throttle response
Last edited by wes-cummins; Jan 16, 2010 at 08:32 PM. Reason: Automerged Doublepost
Old Jan 16, 2010 | 08:50 PM
thought you were talking about the elbow on the turbo.
Old Jan 16, 2010 | 09:09 PM
no the one going into the afc had very small hole in it mabey 1/32, so i drilled it out to 1/8
Old Jan 16, 2010 | 09:48 PM
did you notice much of a change at all?
Old Jan 17, 2010 | 12:41 PM
it seemed like the afc fueled up little quicker when i stomp on it from a dead stop.
my97-6gun
May 3, 2015 09:43 PM
easttn12valve
Jan 17, 2015 11:09 AM
NiNjAassasin545
Dec 2, 2014 11:40 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
