Dash Problems.
Old Jan 15, 2010 | 08:56 PM
bjohnson1781's Avatar
Default Dash Problems.
When I turn the key to on gages will not work even after starting.When this happens all the gages,chimes radio cruise control and switched dome will not work.Fuses ok,Independent shop checked cluster found nothing.The dealers here never heard of that happening.So I really don't want them to start replacing parts.Hoping somebody here might have seen this before.When I turn the key off after a while chimes and dome works.But truck cranks and runs fine.
Old Jan 19, 2010 | 09:36 PM
ArizonaRedneck's Avatar
have you had any luck with your problem
Old Jan 19, 2010 | 11:34 PM
Mdub707's Avatar
Do a search on powerstroke.org I'm fairly certain I saw someone else with this problem when I first joined a while back. I'll do some searching myself and see if I can find anything.
Old Jan 25, 2010 | 07:10 PM
Well first off.A Ford dealer gave me a phone number.This guy repairs dash clusters.Well he had it about four days.Sent it back said it is the truck because nothing wrong with dash.Took it to a local dealer.They called me today said it is the dash cluster.Will have one by Tuesday.
Thanks for asking.
No rat infested wires so I took it to a dealer.Was dash cluster.At least I hope.
There is more to this.Read what I replied to Arizona Redneck.
Last edited by bjohnson1781; Jan 25, 2010 at 07:10 PM. Reason: Automerged Doublepost
Old Jan 25, 2010 | 07:15 PM
well i hope you get it repaired sounds to me like some body wanted to give you the runaround for a little bit
Old Feb 1, 2010 | 12:21 AM
Yes got it fixed at dealer in Liberty TX.Cost me $473.00 The one that said it wasn't my dash will not get a good recommendation from me.I think he does a lot of work for used car dealers.I'll let you guess what I am thinking.
Thanks for trying to help.
Got me a EGR block off plate ordered for my up pipe.Going to see how tough that is to install.
casper83
Jun 29, 2015 07:37 PM
Brushout
Audio Equipment/Electrical
Mar 18, 2015 10:54 PM
Zachbishop
Feb 10, 2015 10:23 AM
Ol Goat
Jan 22, 2015 02:16 AM
suzan
Dec 2, 2014 03:03 AM
