rough runnin 6.2 NEED HELP
Old Jan 15, 2010 | 09:05 AM
smoking62's Avatar
Exclamation rough runnin 6.2 NEED HELP
hey guys im 18 and have alot of experiance with smalll engines. diesels are another story. i have a 6.2 and it leaked fuel through the valley... so i bought a 35 dollar pump off ebay it was an as is buy. well i slapped it together and it wouldnt fire. so i took the top cover off the pump and filled it with diesel, and it ran hard when i throttled up it rapped out quickly at half throttle but it idled. when i got the pump i turned the fuel screw up and i noticed that the arm that pivots when the throttle lever is rotated, it pushes a little rod in the pump. well the ajustment screw was all the way out. on my old pump it was in all the way? i took it on a half mile test drive and it died and woudnt start please help
Old Jan 16, 2010 | 10:10 PM
bigcountrysg's Avatar
Your pump is most likely out of adjustment. Only a trained tech should adjust the pump. This is why I will not talk about how to adjust the pump.
Your lucky the engine did not run away on you.
Old Jan 16, 2010 | 11:58 PM
dealwithit's Avatar
are you sure your lift pump is working properly?
Old Jan 17, 2010 | 12:35 AM
Woody35's Avatar
i would not trust a 35 dollar injection pump off ebay. go to a local diesel shop and get it looked at
ssmith.77
Nov 25, 2018 06:56 AM
bdbfam
Aug 31, 2015 09:06 PM
Snoobly
Dec 11, 2014 11:59 AM
Caveman94
Dec 8, 2014 12:21 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
