weird noise
Old Jan 15, 2010 | 12:33 AM
jake 94's Avatar
Default weird noise
Not sure what's going on but I went wheelin the other day and after I was done at about 40 mph the front end starts making a grinding noise and all sorts of bad sounds but then you drive it around for about 10 or 15 min it goes away.can anyone help me out thanks
Old Jan 15, 2010 | 12:49 AM
sneed1rr's Avatar
FormerVendor
Check your backlash on your gears. is it a grinding or more of a whine?
Old Jan 15, 2010 | 06:17 AM
TwinStackPete379's Avatar
Wheel bearing?
Old Jan 15, 2010 | 10:35 AM
12valvetater's Avatar
Intermediate shaft not unlocking.
Old Jan 15, 2010 | 12:12 PM
jake 94's Avatar
it does it even if i dont put it in 4 wheel
Old Jan 15, 2010 | 04:37 PM
sneed1rr's Avatar
FormerVendor
if the backlash is to far out it will make noise untill the gears heat up and expand then the noise will go away. might not be the cause but I would start there
Old Jan 15, 2010 | 07:13 PM
smoken's Avatar
Default CAD
With your set up trash the CAD set up on your truck and go with a Hub conversion set up with CAD delete, will not regret... Do not wait like I did untill the weak set up chews the splines off the ends of the shaft and leaves you with out 4wheel drive in the dead off winter just my whole two censt worth....
Old Jan 15, 2010 | 10:59 PM
seandonato73's Avatar
x2 my buddys jeep truck did that to him, a little bushing went out that keeps the two shafts alligned, and left him without 4x4. kinda sucked having to pull him up his lane till he fixed it.
Old Jan 16, 2010 | 09:10 AM
R&RDiesel's Avatar
FormerVendor
Im thinking wheel bearing.
chootem
Jul 18, 2015 08:29 PM
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
dutchsupreme
Dec 18, 2014 01:44 PM
