painting stacks?
Old Jan 14, 2010 | 08:42 PM
bowtech's Avatar
Default painting stacks?
i am going to be doing a single maybe a double idk but im going to paint it black. would i use just some engine enamel or what?
Old Jan 14, 2010 | 08:47 PM
Lil Red Express's Avatar
As high temp as you can find. Use some 250 grit sandpaper to rough it up.
Old Jan 14, 2010 | 08:56 PM
Whit's Avatar
Site Mascot
get it powder coated if ya can......other wise stove paint
Old Jan 14, 2010 | 09:06 PM
ArizonaRedneck's Avatar
AEROSOL ENGINE ENAMEL-Hirsch Automotive Products check this out bowtech about as high temp as your gonna find
Old Jan 14, 2010 | 09:31 PM
oglejust's Avatar
i just used engine paint.. no problems with mine, its just gonna get covered in soot anyway
Old Jan 15, 2010 | 12:39 AM
dieseldocter16's Avatar
I scuffed mine w/ a fine scotch brite, the used VHT ceramic paint good for 1500 degrees. Turned out awesome.
Old Jan 15, 2010 | 09:15 AM
FastCR's Avatar
I found a can of header paint good to something like 2200 degrees. duplicolor IIRC.
Old Jan 15, 2010 | 09:45 AM
black99's Avatar
if you ruff it up with 250 grit paper it will show some nasty scratches coarsest i would go with is like 320 or a scotch brite gray fine pad
Old Jan 15, 2010 | 10:32 AM
Thelilbluedodge's Avatar
X2 I'd use some manifold paint
Old Jan 15, 2010 | 10:39 AM
Racer9's Avatar
The stacks are far enough away from the motor that they don't get real hot. Any paint will do.
