G360 to NV4500?
Old Jan 14, 2010 | 07:10 PM
weems04's Avatar
Default G360 to NV4500?
I am looking at putting a nv4500 in my 90 w250 which currently has a G360. What will i need as far as other parts to make this work? will i need to swap t cases too? Is this a difficult job or just a matter of swapping parts?
Old Jan 14, 2010 | 10:11 PM
tltruckparts's Avatar
you will need the tranny and the back engine cover that the tranny bolts to off the newer engine. you will also need driveline mods, and to make a new floorpan as the shifter comes out further back. i dont remember if you can use the old clutch and flywheel or not. and you will also need a new engine crossmember
Old Jan 14, 2010 | 10:36 PM
welderboy250's Avatar
in my opinion the better way to do it is to use a special bell housing that joins the nv4500 to the original engine plate. this alows u to keep the same starter and hydraulic clutch system as they r specific to their own bell. same flywheel, clutch, pressure plate, release fork. u do need a throwout bearing that fits the nv4500 because the tube it slides on is a different size. ull need to make an adapter to bolt the tailhousing to the crossmember and to keep the rear of the trans the right height. u will have to cut a new shifter hole in the floor. if ur good u can use the piece u cut put to patch the old hole. use ur original transfer case. it will mate up just perfectly. u will need to make a bracket to hold the shifter. the driveshafts can stay the same as the overall length when ur done is only off by like 1/4 inch from original
Old Jan 14, 2010 | 10:44 PM
seandonato73's Avatar
nv4500, you can get an adapter kit for like $400 i think
Old Jan 14, 2010 | 11:13 PM
what is this special bellhousing you speak of? havent heard of that
Old Jan 15, 2010 | 12:37 AM
Alwaysworking's Avatar
i would keep the getrag, a nice tight getrag will last a long time and perform great.
i've never heard of anyone blowing 5th gear up in a getrag. and they dont make upgrade parts for the getrag, why might that be?
Old Jan 15, 2010 | 08:35 AM
RSWORDS's Avatar
x2
I've drove my buddies 4500ed 1st gen, didn't like it...
Overfill the rag by a quart, dont lug it down (good advise for any engine or tranny) and it will run as strong if not stronger then the 4500...
Old Jan 15, 2010 | 08:35 PM
tl, the bell im talkin about looks like the original getrag bell at first but it ia the right length and hs the right rear mounting pattern to fit a 4500. this way u dont need the second gen engine plate and stuff that goes with it and the second gen bell: like a second gen starter (yes they look similar but wont interchange, ive tried) and a second gen hydraulic clutch system.
Old Jan 15, 2010 | 09:16 PM
weems04's Avatar
First off thanks for all the great advise. Heres the deal, my getrag needs work and i currently have the chance to buy a 96 club cab 5 speed 4x4 for 2 grand. the guy that owned the 96 hit a cow, however mechanically it is sound. it has 250,000 on it. I wouldn't mind staying with the getrag. Would i be able to buy this 96 and part it out and have enough money left over to fix the rag or would this 96 be a bad investment?
Old Jan 15, 2010 | 10:01 PM
RSWORDS's Avatar
the engine in the 96 os wprth $1500 or so...
