Front Differential?
Old Jan 13, 2010 | 10:18 PM
Fiveseven's Avatar
Default Front Differential?
I have finished a front differential oil change and I was trying to put the 4.3 quarts and I could bearly put 4 quarts .I think got in there like 3 Qt and 30 Oz ,Is that enough or is there another way to put in the extra 5 oz
Old Jan 13, 2010 | 10:25 PM
chpmnsws6's Avatar
If your truck is on level ground and its oozing out of the fill plug, you have enough. When it is oozing out of the fill, it means you are getting plenty of oil coverage on the bearings.
Old Jan 13, 2010 | 10:48 PM
Fiveseven's Avatar
Cool thanks I did had it on my drive way wich was a little nose up so I took on level ground and it was oozing like you say so I am good .Thanks!
Old Jan 14, 2010 | 12:01 AM
01quadcab's Avatar
the axle tubes will still have some fluid left in them. so no worries
Old Jan 14, 2010 | 12:21 AM
Fiveseven's Avatar
Well I kinda tilted the truck one side at a time because the oil looked like a coffe with cream and felt like water
Old Jan 14, 2010 | 12:40 AM
Actually, from what I understand the level is supposed to be 1/2" below the fill plug hole. Have heard that having too much can cause the diff to run hot.
Old Jan 14, 2010 | 12:52 AM
chpmnsws6's Avatar
Originally Posted by Dr. Evil
Actually the level is supposed to be 1/2" below the fill plug hole. Have heard that having too much can cause the diff to run hot.
I stand corrected! Again, Dodge does not follow common knowledge
Old Jan 14, 2010 | 01:06 AM
It didnt seem right to me either - common sense would cause you to think more is better.
I generally fill it to the bottom of the hole anyway.
well, that sounded pretty kinky....
Old Jan 14, 2010 | 01:03 PM
Fiveseven's Avatar
One more question guys I checked my rear diff oil and it looked like honey with small little bubbles in it I dont know if its to time to change it or not I was planning on change it anyways .I am the second owner and I bougth the truck with 141000 and rigth now I got 152500 on it and I dont know if it had been serviced or not before what do you recommend ? (planning on using amsoil on the nv4500 oil and engine oil but since amsoil its kinda expensive would like to do whats more important first the rear diff or the nv4500 )
Old Jan 14, 2010 | 03:54 PM
DeLuzGN's Avatar
You're on the right track bud.
Since you don't know what's been serviced, might as well start from scratch and just plan on servicing everything so you know when it's been done.
As far as the nv4500 vs the diff, that's a personal choice. If it were me, i'd probably do the tranny first since it's a more expensive item and often neglected.
