Noise in my 6sp
Old Jan 13, 2010 | 08:39 PM
haulitrite's Avatar
Default Noise in my 6sp
I just bought a 05 with the 6sp. I am trying to figure out all of the noises and only one that really bothers me is in the transmission/clutch area.
When I release the clutch and the RPMs are below 1000 there is a rattle sound from the transmission. I have heard this noise when driving semis and i hit to high of a gear, but that was when there was 80,000 lbs fighting back.
Is this normal?????
Old Jan 13, 2010 | 08:45 PM
07redsled's Avatar
stock clutch? my dual disc rattles and the g56 makes a little noise. check the fluid and go from there
Old Jan 13, 2010 | 08:50 PM
haulitrite's Avatar
The truck seems to be untouched with 37,000 on it so I would guess it is stock.
The transmission fluid was clean but I changed it anyways. still the noise
It does sound like the clutch, it doesn't slip at all but that rattle makes me worried.
Old Jan 13, 2010 | 09:10 PM
07redsled's Avatar
pull the trans and see if it really bugs you if its not slipping and fluid is clean and it shifts ok doesnt pop out of gears or grind i think your ok
Old Jan 17, 2010 | 04:25 AM
black sheep's Avatar
my 05 does it too, i read a few threads on here that said its normal, hub something yada yada yada
Old Jan 17, 2010 | 08:35 AM
harry22's Avatar
my 96 did this for the 70k miles i put on it.had 80k when i bought it. i know its a 5 speed compared to a 6 but when i replaced the clutch i had the fly wheel machined because there were a couple hot spots. i think what happens is the clutch chatters on these hot spots and what we here are the springs in the disc dampening the vibrations. It went away after i had the knew clutch in with the machined fly wheel. thats just my explaination someone who knows alot more will chime in
Old Jan 18, 2010 | 09:43 PM
haulitrite's Avatar
Everyone says that there is some noise in the clutch, I will just wait till it goes then prob get a SB.
Old Jan 19, 2010 | 01:42 PM
harry22's Avatar
sounds like a good plan to me!
Old Jan 19, 2010 | 05:18 PM
392hemix's Avatar
I just got an 04 with the 6speed, it does this ecaxt thing your explaining, figured it was the clutch, i will find out when i get a new one after this ones toast
Old Jan 20, 2010 | 06:37 AM
vrodrex's Avatar
Mine's done it since new. Just the nature of the beast.
