Holley blue/return line?s
Old Jan 12, 2010 | 01:00 PM
1STACK's Avatar
Default Holley blue/return line?s
Alright guys I have a holley blue with no return line right now but the pump gets really hot. Should I put a return line on it, if so how should I go about doing it? Put the regulator on and run a line out of it and tie into the stock return or what?
Old Jan 12, 2010 | 01:19 PM
Jet A Fuel's Avatar
IMO you need a check valve tee'd in to the supply line that opens at around 15 psi and recirculates it back to the tank.
Old Jan 12, 2010 | 01:39 PM
NadirPoint's Avatar
The Holley is a 14psi pump. Operating temperature will not be affected much by a regulated feed due to the design being a rotary vane driven with an external DC motor.
How hot is "hot?"
Old Jan 12, 2010 | 01:51 PM
Jet A Fuel's Avatar
How hot is "hot?"
Sorry Nadirpoint is right the Holley only did 12 PSI in my Gasser .
X2 on the how hot is it?
Old Jan 12, 2010 | 08:38 PM
1STACK's Avatar
it idles around 14psi it Pretty hot can't lay my hand on it for more than 2-3sec. I thought it was the pressure bucause of the stock return system.
Old Jan 15, 2010 | 10:46 PM
seandonato73's Avatar
the return shouldn't be a problem i think the truck would act up if something was up with it
Wigginsmk
10
Jun 2, 2015 08:06 AM
