Exhaust Replacement
Old Aug 12, 2007 | 10:10 AM
Default Exhaust Replacement
After installing a new industrial VP, my mpg was 21.6. Just installed the XZT+ and have it set to 35hp (fuel econ mode), response is good. Will follow-up in a few days regarding the mpg and performance.
What would a 4in exhaust do for my engine? I tow very little and I try (emphasis on try) to drive conservatively. Exhaust temps are from 600-700 (normal traffic) to low 900s on acceleration and climbing. From what I have read, larger exhaust will lower my exhaust temps, Question do I need to lower the exhaust temps given the above info?
What will I gain from swapping to 4in? Will there be a difference in performance? The reason I’m asking is that I have red threads that described very little increase in performance.
Last part
Which single exhaust do you recommended?
Old Aug 12, 2007 | 10:14 AM
2141pete's Avatar
4 inch will sound bettdr EGT's and give a litlle gain in power maybe. I would reccomend a cheap one. I couldnt justify spending twice as much on an SS system when they really dont put out any condensation to rot it out.
Old Aug 12, 2007 | 10:25 AM
Given what my egt are, do I need to lower the temp?
By going cheap do you mean aluminized vs steel?
Old Aug 12, 2007 | 11:39 AM
2141pete's Avatar
Mine are about the same but I would like to be lower. It doesnt look like you are putting too much fuel to it so i guess you are fine there. I went aluminized. You can get a good aluminzed fit for around $275 or less if you shop around.
Old Aug 12, 2007 | 11:43 AM
did your mpg go up?
Old Aug 12, 2007 | 11:57 AM
bow2no1's Avatar
this is the exhaust i have. http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWDVW
it's the cheepest aluminized on i found. i have had it on for about a year now.
still looks like the day i put it on.
Old Aug 12, 2007 | 12:00 PM
bow
Did your mpg and hp increase and how does it sound?
Old Aug 12, 2007 | 12:05 PM
bow2no1's Avatar
sounds great!
i put the system on before i stated driving the truck.
my rig needed alot of work when i bought it. i have never checked my mpg and i didn't drive the truck befor i put the system on... sorry i can't give you a better answer
Old Aug 12, 2007 | 12:34 PM
2141pete's Avatar
I runthe crap out of mine so I am not sure on Milage but i get descent miles still. It sounds awesome but I am getting ready to go to 5 inch. 5 inch sounds AWESOME. On a mosstly stock truck i would say 4" is your best bet.
Old Aug 12, 2007 | 06:48 PM
Would it be safe to assume that increases to hp & mpg are minimal after changing your exhaust from stock to 4 in. Benefit is lower egt.
