electronic to mecahnical injection
Old Jan 10, 2010 | 10:22 PM
tweeter31's Avatar
Default electronic to mecahnical injection
I was wanting to switch a 95 6.5 TD over to mechanical injection since the engine will be dropped into a 1993 truck. It has a manual transmission so no worries there but i dont know what else is needed. Can i just put my injection pump of the 93 on the 95 engine and change the lines or is there more that needs to be done? Any help would be appreciated
Old Jan 10, 2010 | 11:07 PM
Woody35's Avatar
so if i understand you corretly your just putting the pump and the lines from the 93 on the 95. if so then your good to go. nothing else needed. just going to have a bunch of senors with nothing to plug into
Old Jan 10, 2010 | 11:30 PM
tweeter31's Avatar
ok. Thanks. The emty sensors shouldnt affect anything though if i am thinking correctly. If i'm wrong please correct me. Ive got all the parts to the the 93 engine but the block was broke where the starter mounts to it and it couldnt be fixed. And i bought the truck thinking i could fix it but it was destroyed. I was going to find another block and do a rebuild but the kit is so expensive, i'm trying to find an alternative method and i found a running 95 6.5 for very cheap. If you have any other solutions, i'm all ears.
Old Jan 11, 2010 | 12:55 AM
Woody35's Avatar
sensors will just look kinda wierd. i would zip tie them together. what your doing sounds good just hope the 95 has a good engine
Old Jan 11, 2010 | 01:01 AM
FastCR's Avatar
i just talked to someone a couple days ago that did this and he didn't have any problems. basically use the long block out of the newer motor.
Old Jan 12, 2010 | 05:30 PM
tweeter31's Avatar
thanks guys for the response and advice, havent been on here very long but seems like a very good community of people. Thanks again.
Old Jan 12, 2010 | 08:41 PM
Woody35's Avatar
your welcome
dwmeehan
Jan 29, 2025 12:13 PM
1997silverado
Sep 11, 2015 11:27 PM
nelly559
Feb 17, 2015 06:49 PM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
