Engine Rebuild Kits?
Old Jan 10, 2010 | 12:28 PM
Turbohunter's Avatar
Default Engine Rebuild Kits?
Hey didnt know if anyone knew where to get a GOOD rebuild kit. I have alot of engine oil coming out the blow by, more then what should so i guess its time to do rings. So i figure while the motor is tore down might as well do everything. Hoping some one has a package deal put together to help me with this. Any input would help. Its a 2001 Dodge Ram
Old Jan 10, 2010 | 12:37 PM
Blue01cummins's Avatar
how many miles does your truck have?
Old Jan 10, 2010 | 12:56 PM
just over 145,000
Old Jan 10, 2010 | 01:18 PM
were is the oil coming out at? and that is not many miles to need a rebuild kit.. what is all done to the truck??
i would think you should go to the price quote and start this post there! other than that idk were you live but you could get a rebuild kit from cummins
Last edited by Blue01cummins; Jan 10, 2010 at 01:18 PM. Reason: Automerged Doublepost
Old Jan 10, 2010 | 02:08 PM
captain_stabbin's Avatar
wow, never thought i would see a diesel needed to be rebuilt with that low of miles!
Old Jan 10, 2010 | 02:24 PM
Well the blow by on it is ridiculous. The rings are shot. Basically stock motor the previous owner I think beat it hard. I wanna pull it and rebuild it. The oil comes out the breather tube like a quart a week. And the oil pan but that just needs a new pan gasket.
Old Jan 10, 2010 | 06:52 PM
dukeboy_318's Avatar
hmmm, if its that bad the previous owner must have been really beating it hard, i mean very hard or he had aftermarket stuff on it and took it off before you got a hold of it.
Old Jan 10, 2010 | 07:08 PM
Uncle Bubba's Avatar
Previous owner must have forgot to put the new oil in at the end of the oil change to be that bad that early in life. If he did I wanna know what kind he used so i can be sure i never use it. That's insane.
You sure you just don't have a plugged up line someplace that is not lettin it circulate. Dump a can of seafoam in the oil and let it run for 5 minutes or so and then change the oil just to see what comes or to see if there is any improvement.
Old Jan 10, 2010 | 07:12 PM
turbo20psi's Avatar
What kind of oil filters were on it when you brought it? There was a problem with certain oil filters that clogged up the cooling nozzles in the pistons to cool the rings.Meaning the oil filter would break off a small piece and clog up the nozzle.
Old Jan 10, 2010 | 07:14 PM
especially if they are frams. i aint ever using them again, not after on my 78 360 i found parts of the inside of the oil filter IN my oil as i drained the pan.
