Trans Temp
Old Jan 10, 2010 | 05:53 AM
slosh2500's Avatar
Default Trans Temp
Where is the best place to mount the transmission temp probe? Someone on here told me in the back of the trans at the service port of the pass side of truck.???? Just seemed like it was to long but it did fit. Just kinda second guessin it as i just spent a ton getting the trans rebuild. Thanks for all the help..
Old Jan 10, 2010 | 11:36 AM
dieseldocter16's Avatar
Yes there is a service port on the pass. side of the trans, assumeing your 02 2500 is a dodge w/ a 47RE. If not you can always get an aftermarket trans. pan w/ a port for the temp. sender.
Old Jan 10, 2010 | 02:08 PM
biged681985's Avatar
this is what ima use on my truck
http://doghousediesel.com/catalog/i280.html
Old Jan 12, 2010 | 04:53 PM
2500superram's Avatar
i plan on putting mine in the tranny line also.seem's better to get a reading from the fluid comming out of the trans.
Old Jan 12, 2010 | 05:08 PM
NadirPoint's Avatar
Which one? Different places in the trans will show very different temps. Torque converter is hottest, after the cooler is coolest and the pan will moderate somewhere between the two. Put it in the pan unless you are installing 2 or more sensors to constantly obsess over your transmission temperature or like scaring yourself watching the TQ temp spike.
Old Jan 12, 2010 | 05:10 PM
the feed to the cooler is where ,i'll be putting mine.
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
casper83
23
Jul 27, 2015 01:53 PM
doodieroot
May 10, 2015 11:48 PM
emilio2496
8
Jan 13, 2015 05:03 PM
