rattling and low power till i back of throttle?
Old Jan 9, 2010 | 06:22 PM
Sagefisher's Avatar
Default rattling and low power till i back of throttle?
Sorry this may be a stupid question but this diesel stuff is still new to me, I have some new parts coming next week, gauges, full exhaust and intakes...along with a 100 plate from Mr Whit (what a decent guy!) but before these things go in I want to ensure there are no problems I should deal with first.
When driving the truck (stock) I notice that to increase speed I actually have to back off the throttle otherwise is holds at about 22-2300 and rattles like pre-ignition when I back off it gets quieter and seems to have more power.
Any help?
thanks guys!!!!!
Old Jan 9, 2010 | 06:28 PM
Lil Red Express's Avatar
does it smoke when it does this "pre-ignition" thing? what color of smoke?
Old Jan 9, 2010 | 06:34 PM
Sagefisher's Avatar
nope truck doesn't smoke at all, mind you it's always raining some maybe I cant see it?
I should add I have only had truck for a couple of weeks and history is unknown.
Old Jan 9, 2010 | 07:32 PM
12valvetater's Avatar
Fill out your sig. Do you have a manual truck? It could be that the timing is way off and the further the increase the rack the lower the timing is.
Old Jan 9, 2010 | 08:08 PM
Sagefisher's Avatar
Sorry truck is an auto, since I have those performance parts coming next week should I install them then take it in and get timing set? I don't have the tools to check the timing out myself.
Old Jan 9, 2010 | 09:14 PM
Sounds like your timing is a little off. Have you changed the fuel filter since you've had it?
Old Jan 9, 2010 | 09:52 PM
Sagefisher's Avatar
Nope I have changed the filter yet, but if you think that will be a start I will do that and the oil tomorrow. Sorry didnt even think of that to start with
Old Jan 10, 2010 | 07:21 AM
tpcdrafting's Avatar
Is it hard starting? It could be a fuel pump.
Does it do it cold and hot?
Timing is quite possible as well.
Old Jan 10, 2010 | 09:01 AM
Sounds like its starving for fuel on the top end. If the fuel filter change don't fix it then you need to have the timing checked. Then have it set at 15*.
I wonder if someone in the past didn't turn the rack press down, attempting to get better mileage
Old Jan 10, 2010 | 10:22 AM
R&RDiesel's Avatar
FormerVendor
Deffinelty replace fuel filter first and then timing then let us know. How do you turn the rack pressure down? I am unfimilliar with this.
