best cheap 1st mods?
Old Mar 19, 2007 | 07:46 PM
Lostnwalmart's Avatar
Default best cheap 1st mods?
best cheap 1st mods? i would like to know for a buddy of mine he may be getting a 97 5 speed and he wants some performance out of her. perferably free or cheap thx men =D
Old Mar 20, 2007 | 12:22 PM
Mslaughter's Avatar
I would say grind/slide fuel plate, adjust afc housing and starwheel. All free mods.
Old Mar 20, 2007 | 01:41 PM
diesel junkie's Avatar
put a washer between the pump and rack travel plug, you can also take the silencer ring out for more whistle
Old Mar 20, 2007 | 01:59 PM
Plhorseman's Avatar
can you elaborate on the washer between the pump and rack travel plug?
Old Mar 20, 2007 | 02:08 PM
DBogo's Avatar
yes i will, you take the rack travel plug out of the front of the pump, to do this you either have to grind a little bit of your timing case or loosen up the bolts on your injector pump to get it out, you may be lucky and get it out without doing that but i highly doubt it, once that is out either buy a mack plug:q: for it which i dont know the part number of it but i can get it for you or put a washer on the plug doing that will allow the fuel rack to travel farther into the plug therefore allowing more travel, out of the two of them i would spend the $5 and get the mack plug because then you can have a decent amount of threads into the pump instead of one or two with the washer
Old Mar 20, 2007 | 02:16 PM
Plhorseman's Avatar
Thanks...brain fart on my part...:doh:the "mack plug" mod.
Old Mar 20, 2007 | 02:23 PM
DBogo's Avatar
theres your number for it too if you need it
Old Mar 20, 2007 | 10:47 PM
vegburner's Avatar
where can it be bought?
Old Mar 21, 2007 | 06:09 AM
DBogo's Avatar
any mack dealer or most likey any bosch dealer
ratherBcummin83
Oct 18, 2016 03:49 PM
2004LB7
29
Feb 29, 2016 06:00 PM
Robby21NoGlowPlugs
May 8, 2015 04:29 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
rtbcoop
Dec 30, 2014 02:13 AM
