12 valve conversion
Old Jan 9, 2010 | 09:36 AM
99_cummins's Avatar
Default 12 valve conversion
i did a 12 valve conversion because i had the 99 and my block cracked. everything seems to work good i just do not have overdrive. but i am also using my 24 valve transmission. i was wondering if because the motor i bought is a manual and does not have a throttle positioning sensor if that could be the reason. let me know thanks
Old Jan 9, 2010 | 09:39 AM
12valvetater's Avatar
Yep that's the problem. We did the exact same thing with my buddies 99. With his though it wont **** out of 2nd. We are tired of messing with it so we're putting an NV in.
Old Jan 9, 2010 | 11:58 AM
biged681985's Avatar
does your stock tach work? if so how did u manage that?
Old Jan 9, 2010 | 12:27 PM
latenighthaulers's Avatar
put a pot in place of the tps real easy to do and you can also put a lockup switch in
Old Jan 9, 2010 | 01:09 PM
for overdrive on mine, i put in a lock up and also put a lock up switch in, cause neither of mine worked
Old Jan 9, 2010 | 02:55 PM
99_cummins's Avatar
i already have done that
did you do a 12 valve conversion too
Old Jan 9, 2010 | 09:26 PM
yes i did. when we got it goin, it wouldnt shift into 4th or lock the tc up. but i tried and tried to get the tach to work, with no luck. called up haisley and schieds, they told me i would have to get a 98 12v harness and computer to get it to work, or get an aftermarket tach.
Old Jan 9, 2010 | 10:30 PM
99_cummins's Avatar
i used the 98 twelve valve wiring harness put i used the 24 valve pcm box. should i put the twelve valve pcm one in
Old Jan 9, 2010 | 11:09 PM
idk, thats what i was told, but i couldnt find one with a good enough price. does ur tach work? did the 12v u put in have the spot for the crank sensor in the block?
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
sotomo
Nov 24, 2014 07:29 PM
