Removing engine from 97 4x4 dodge
Old Jan 8, 2010 | 07:18 PM
97 dodge's Avatar
Default Removing engine from 97 4x4 dodge
I removed my cummins from my 97. What a bear!!! Does anyone have any advice on the install. I am not sure what else you have to remove but to get it out I had to remove 3 valve covers, the rear lifting bracket and it was still very tight. Any advice would be appreciated.
Old Jan 9, 2010 | 10:24 AM
Diesel Nut's Avatar
Pull the head and it will be much easier. The lifting brackets on the head are for assembly line use only, the motors are placed in the frame before the body is mounted.
Pull the head and use some 12mm bolts to bola a chain to the block. Careful not to ding the surface. You want the chain pretty close to flat. This should give you plenty of room to set it in there.
Old Jan 10, 2010 | 07:26 PM
dave2001's Avatar
Hopefully you have the front end off. Having just seen this done and helping to some degree. Our motor also had the transmission attached. It is easier in my opinion to get it back in because you've seen how to get it out. We left the valve covers off (12 valve) and covered the top of the engine with clean rags. Being able to readjust the angle is a must. We used a floor jack on the tranny to raise it while we were guiding the engine into position. We also put the motor mounts/brackets on once the engine was close to its final position. Just take it slow and easy. We used one of those two ton engine lifts. The hardest part is getting the oil pan to clear the crossmember. It may be easier to do it with the pan and oil pickup off the engine, then install it after the engine is in the truck. Just a thought. Anyway good luck.
Old Jan 10, 2010 | 07:33 PM
07redsled's Avatar
just did my common rail in my 04 keep the chain as close to the cover as possible remove the rear lift loop bolt the chain to the head in the back floor jack on trans bumper and the cross bar in front of the rad must be cut and removed and welded once back in take your time we used 4 people 2 working the crane one on top of engine one under the truck good luck
burndiesel
10
Feb 7, 2023 01:15 AM
river rat
May 18, 2015 05:04 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
99dodge
Dec 19, 2014 05:52 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
