Getrag woes...
Old Jan 8, 2010 | 04:34 PM
93_Fummins's Avatar
Default Getrag woes...
I currently have a Getrag 360 in my Fummins from my donor '90 Dodge W250 and it has a problem...
The transmission shifts smooth as can be, has always been overfilled and is clean as a virgins honey pot on the inside....however...whenever I go to downshift out of 5th gear, the shifter seems to slide out of the rails and I'm lost in no mans land, stuck in 5th gear, until I fish it back into the rails and try downshifting again. It only does it in 5th and only on the downshift. The stick does seem to wander waaaaaaaaay away from me when I shift into 5th...like over in the passengers lap. I was wondering if this is a problem with sloppy shift rails and a worn out top cover or if I have deeper issues. I've taken the lid off and everything "looks" and "feels" okay with the gear assembly itself, but the lid is a little worse for wear I'm afraid.
Does anyone have any suggestions....other than swap in an NV4500/5600?
Thanks!
~Jeremy
Old Jan 8, 2010 | 07:43 PM
seandonato73's Avatar
my friend zachs 91 does that..... our tranny guy says he can fix it with a bit of welding and a die grinnder but i dont know to what..... i would guess he means to the pivot end of the shifter but i may be wrong.
Old Jan 8, 2010 | 08:14 PM
tltruckparts's Avatar
my 5 speed did the exact same thing, and just this last week it actually got jammed and wouldnt come out of gear period. i had it checked out today after removing the shift tower and the rails are all jacked up, so now i need a new shift tower. hopefully yours doesnt follow the same route mine did
Old Jan 8, 2010 | 08:20 PM
FIRST GEN. JAKE's Avatar
mine got stuck in 5th gear. made a sound too. finaly got it to workin and now the thing wants to pop out of gear all the time in low gears. trans. guy at a shop said sounded like shift forks. heck idk. i wish it was fixed though
Old Jan 8, 2010 | 09:59 PM
tjsmokin's Avatar
good luck man. mine started that crap and after hauling a trailer with 13 heiers it decided not to go into any gear. luckly i had a second gen trany sittin atound around ready to replace it. the shop wanted 1700 to fix the getrag.
Old Jan 10, 2010 | 10:54 PM
93_Fummins's Avatar
Anyone have any leads on a new top cover? Or have any advice in "fixing" one?
I hear all they do on a rebuild is bore the rail guides out and replace them with inserts and such to tighten everything up, maybe insert new roll pins and speedy-sleeves where needed, but I wasn't sure if those were available parts of custom fabbed...?
What about the "welding" fix? Anyone have any ideas on that? Anything to keep the old rag alive until I can look into something else...
Old Jan 10, 2010 | 11:27 PM
i made a call into a local transmission shop to get one rebuilt. they will get back to me in the morning so ill let you know. as for new ones i cant find them anywhere at all.
what is this welding fix your speaking of?
Old Jan 10, 2010 | 11:48 PM
CHEMMINS's Avatar
Dodge Getrag 360 manual transmission parts, rebuild and overhaul kits, save money! - Drivetrain.com
$475 with the $100 core deposit.
Old Jan 10, 2010 | 11:50 PM
dshane62's Avatar
there is a place in las vegas that rebuilds getrag shifter top i cant recall the name
the price was like 350-400 sorry its a big place in vegas mine does the same thing sometimes seems like its getting more often
Old Jan 10, 2010 | 11:57 PM
freak007's Avatar
call Zumbrota bearing and gear... google will get you a website and phone number. When I rebuilt my Getrag they were cheaper than anywhere else AND had everything in stock
Jladanyi
Jul 4, 2015 02:43 PM
JFreeman510
Jul 2, 2015 02:18 AM
Da Bomb
Diesel Engine Conversions
Oct 6, 2014 09:18 PM
wvwelder89
Sep 28, 2014 02:23 AM
